My rear view mirror is auto dimming at night but it does not seem to work any suggestions???
Check the ribbon in the headlining,some have had the same problem before,there's a thread on here about it,do a search,you should come across it,good luck.......
sorry should have said supposed to be auto dimming. any way sorted the problem the fuse number 27 in boot was missing... 7.5amp
Is the little orange light working on the bottom of the mirror (the one that lights up the gearstick at night)
yes its working now... althought i must say the only use for that light is to distract you by lighting up the air freshener
