Thread: Xenon - one up, one down
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Xenon - one up, one down
    Turned on the factory fit Xenons last night (2002 GSi) and noticed that n/s one was lower than o/s, as if it had stuck in it's lower position.
    So I thought I'd adjust it to equal the o/s. Bad move, cos when I turned the ignition off and restarted, the n/s one was now higher than the o/s. So readjusted n/s again !!!
    Question is, do the Xenons have a motor as such which makes them go up and down (they do this when you first switch on) and do you think it was just a glitch or should I start taking things apart??
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    IIRC they will have motors because all factory fit Xenons have to be self levelling. HTH
    Mar 2007
    Finland
    Hi!
    The factory fitted Xenons have a motor inside both headlamps, and they are automatically adjusted. When you switch them off, the motors will drive the Xenons to lowest possible position. Again, when swithced on, they will be set to the default "on" position.
    I had a failure in the left headlamp motor a year ago, left Xenon remained in the lowest position. The check control system informed failure in the headlamp motor, so it has been replaced.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Jay-C View Post
    Hi!
    How much was it m8? Might need to set some cash aside for this one.
    Edit - sorry Jay-C, see you're in Finland so costs won't be relevant really.
    Last edited by gtr1000; 5th March 2008 at 14:51. Reason: Failed to read previous posts correctly.
  1. To Xenon or not to xenon
    By Vectralicker in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2011, 15:28
  2. hid xenon
    By vectra_ in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2010, 13:52
  3. Xenon
    By Mrsan in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2008, 22:36
  4. xenon kit
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2007, 10:33
  5. Xenon/HID kit X5
    By Marky in forum Parts for sale
    Last Post: 29th March 2007, 12:58
