Thread: scraping noise from rear. rear brakes? upgrade?
    Regular Member Whippy's Avatar
    Oct 2007
    wirral
    Default scraping noise from rear. rear brakes? upgrade?
    1.9cdti(150) 56plate
    got a slight problem and it's doing my head in now.
    it's not constant so i'm not sure what to look for.
    there's a scraping noise coming from the rear of the car.
    when i brake from speed i notice it more. or brake at low speeds.
    doesn't seem to do it inbetween?
    worst case worst, if they need replacing what should i upgrade to?
    are the 314mm disks a straight swap?
    is it 314 front & rear or just front? if so, what's the rears?
    also, any part numbers & prices would be appreciated.
    ta.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Just fronts mate. Rears are only vented I think.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    fronts are vented and come in different mm and the rears are one size i belive and are solid
    Regular Member WHOOSH05's Avatar
    On the back wheel
    Some gsi's are vented on the rear.
    On a 1.9 CDTi (and 1.8, 2.0/2.2 DTi) the rears are 278mm solids. On the 2.0T, 3.2, 3.0 CDTi and 2.8T they are 292mm vented.
    With regard to the scraping, this is something I had in the past (292mm rears on my 2.0T). Most noticeable when I reversed off the drive first thing and when initially driving at low speeds. Never found a cure for it, even after cleaning up the pads and discs. In time I needed to change the discs and pads due to them wearing. After that, never had a squeak, or scrape, out of them.
  1. Estate rear wiper Scraping!
    By MadOnVaux! in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2012, 15:36
  2. Scraping noise from rear
    By Benners in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2009, 09:29
  3. scraping noise with brakes
    By dodus in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2009, 20:41
  4. upgrade rear brakes?
    By aerodynamic18 in forum Handling & Braking
    Last Post: 23rd May 2008, 20:45
vectra 3.0 cdti rear wheel noise
