Results 1 to 10 of 14
Thread: Hello all and HELP!
    Regular Member JonV6's Avatar
    Cardiff
    Default Hello all and HELP!
    Hi everyone,
    just joined the dizzy heights of the Veccy C having left the Corsa C forum! I've gone and bought myself a 3.0 V6 CDTi Elite and very nice it is too.
    I had a few LED type 501 bulbs lying around so decided to put them to use in the Veccy. After trying the sidelights and getting the fault warning I decided to refit normal bulbs and look elsewhere for a use for the LEDs.
    I decided to replace the interior lights in the end. Having replaced the 2 front courtesy lights, I was pleased with the result so decided to replace the 2 front map lights and rear reading lights. This is where the problems started.
    After changing the rear reading lights with the same 501 LEDs, the interior lighting had a fit. None of the interior lights work when the doors are opened. Some can be turned on with the switch, although are not very bright and some are just dead! There is also a clicking coming from the glove box fuse box (too many boxes LOL!) and the lights flash in time with this if I turn on more than 3 of them!? The clicking stops if I remove the battery overload protection fuse! I have refitted the standard bulbs and the problem persists.
    Having had a look through the forums, I found some similar symptoms but nothing exactly like this. I have checked fuses and they all look OK and am now wondering if it's the lighting control box or a CANBUS problem,
    Can anyone please help? would love to get to the bottom of this without visiting the local Vauxhall stealer! Thanks guys!
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    mate i cant help but someone will be along soon who can
    Regular Member wardy's Avatar
    Chichester
    Hi Jon,
    Crackin choice of car the V6 engine is a peach!
    Sorry about the problems, never done anything with LED bulbs before, and having read this I won't!
    Hopefully someone will be along with some help.
    the lighting controller HATES 'LED' bulbs...best place for them is in the drawer matey...standard glass bulbs only..
    Regular Member jack's Avatar
    slaming doors since 1976
    ye that was on the forum the other day LED builbs are a no go am afraid in the veccy or signum.
    Cardiff
    Oh man am I having a bad day, a lorry's just taken my drivers side wing mirror off. Starting to think Vectra's aren't for me! Not even gonna ask how much they cost to replace
    Sunny Dartmoor
    Just a bit of bad luck mate thats all,there's a second hand wing mirror on ebay,if it helps..........
    Regular Member Gordon B's Avatar
    Jan 2008
    Washington
    I would like brighter interior lights, anyone know what they are now, and what wattage could I take them up to?
    Thanks.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Quote Originally Posted by Gordon B View Post
    Thanks.
    The interiors are 5w, but you can change these for LED'S as these aren't on the check circuit (including the g/box and the boot).
    Jan 2008
    Washington
    Quote Originally Posted by jack View Post
    Are there any ordinary higher wattage bulbs available which dont cause any problems?
