Thread: Coilovers
    Stoke on Trent
    Default Coilovers
    Can anyone reccomend a decent set of coilovers without payin silly money? I am looking at the £500 mark and would prefer the adjustable ones so i can lower and raise them to suit.
    Gaz
    Stoke on Trent
    Ive just come across these, they seem very reasonable dont they!
    http://www.speedbox.co.uk/products/p...ver_suspension
    What do you think? Would i need to adjust anything else after fitting these? Camber adjustment, tracking or anything? Or should they go straight on without a problem?
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Bigman has fk coilovers on his and i have used them in the past on my other car, very good coilovers in my opinion. ive got KW coilovers on my vec at the min.
    they will fit straight on but u will need, tracking and camber sorted. with the front struts the camber can be altered quite a bit, and when this is altered the trackin will be altered as a result.
    its always good practice to get the car fully aligned after any suspension component change/repair.
    Stoke on Trent
    Cheers mate, how easy is camber/tracking adjustment? Will any kit be required for this?
    Gaz
    if u can find a garage with a "hunter" alignment system, they do camber ( i think thats what the equipment is called, some one will be along soon to correct if im wrong), ive had problems finding a garage near me that can do it.
    its not really a job u can do ureself without the proper tools.
  1. FK coilovers....yay or nay?
    By Jaspa in forum Handling & Braking
    Last Post: 30th November 2012, 14:32
  2. coilovers
    By veccy c in forum Handling & Braking
    Last Post: 27th January 2012, 00:19
  3. FK Coilovers
    By tubby in forum Suspension, Wheels & Brakes
    Last Post: 25th November 2011, 20:05
  4. coilovers
    By ants sri in forum Styling
    Last Post: 29th April 2011, 20:54
  5. coilovers
    By magpie in forum Handling & Braking
    Last Post: 31st October 2010, 11:15
