Results 1 to 10 of 14
Thread: Hi - I need help
    Swindon
    Default Hi - I need help
    Hi guys
    I need help!
    Got a 52 plate 2.0DTi SXI Hatch that doesn't seem to want to start unless the glow plugs come in. I have changed the Fuel filter housing, glow plugs, spill pipes and rocker cover gasket but it doesn't want to play.
    I got it Aug 06 with 90K on it. It has now got 122K and had problems since about Feb 07 and it's just got worse and worse.
    Any suggestions??
    moving you to where more folks can see this post matey..
    are the sypmtoms that you have to wind it over and over on the key to make it start?...
    Swindon
    Default Starting
    Yes - If it goes - It starts at normal speed for a couple of secs then slows right down to about half the speed. I can normally get it to go if I give some gas. If it won't go first time, I have to stop, wait 30 secs and give it another go. Then she usually splutters into life with a big cloud of black unburnt diesel smoke
    Swindon
    Nice looking motor by the way!!
    Nov 2007
    lancashire
    sounds like fuel pump letting in air, sorry to say but very common on this engine and as far as i know a reconditioned pump will be needed, expensive at about £1200 fitted.
    ive seen loads of these on the cabs and last time i was down the diesel injector specialist place he had 7 dti vauxhalls all in with the same problems, these ranged from 1 year old vectra's to 4 year old frontera's
    Swindon
    Ouch!!
    I take it they aren't easy to fit then!?!
    Nov 2007
    lancashire
    i got told the repair shop was paying about £600 for the repair kit for the pump then had to strip and rebuld the pump, calibrate to spec refit to car all + vat of corse.
    Swindon
    Not too much for them to do then! HAHA
    Can you (or anyone) recommend anyone to do it? Specially in Wiltshire or Bedfordshire?
    Swindon
    Do you think it would be possible to put an electric pump in-line to prime the system?
    If so, where and how would it be easiest?
