Thread: rear brake problem guys
    londonderry
    Default rear brake problem guys
    riteo guys rear brake problem replaced all rear pads an discs cause the sounded like they where done but they weren't new pads an discs still doing the same sqeeling an binding an crunching
    while driving there's like a sqeeling sound from the rear
    all genuine parts fitted cleaned an modded to fit perfect before refitted
    any suggestions guys?
    04 1.9cdti 16v sri
    did you assemble them dry or with copper grease?...for some reason the vectra-c and signum do like their pads being fitted with a smear of copper grease on the backs of the pads and the tangs that fit into the carrier.. are you 100% certain that the tiny spring cliup is properly engaged on the piston groove?
    londonderry
    defo plenty of copper grease have a big tub off it ain't scard to use boyo
    West
    Check the handbrake cable/mechanism & return spring.
    I had same problem after replacing rear calipers, i then ended up changing handbrake cable & return spring.
    The springs are shoddy cheap & dont always do there job
    Sunny Dartmoor
    Maybe caliper semi seized,or maybe the handbrake,remember reading a thread on here about handbrake fault worth removing discs and checking handbrake is adjusted correctly,without looking at it or hearing it couldn't think of anything else......
    Let us know how you get on.........
  2. Rear brake caliper problem
    By siadwel in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2012, 16:37
  3. rear brake light problem, bulb ok, please help
    By circushead in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2009, 18:29
  4. new rear brake problem
    By davidjameswest in forum General Chat
    Last Post: 11th May 2009, 10:26
  5. Rear brake problem
    By LGD in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2008, 08:01
