Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: What's required to replace springs and shocks?- Advice please.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Default What's required to replace springs and shocks?- Advice please.
    Hi all,
    I'm going to fit Eibach springs and Bilstein B4 shocks all round on my 1.9 CDTI SRi 150, 55 plate facelift.
    Apart from the springs and shocks, what else will I need to completely carry out the work, ie, re-alighnment, special sockets etc.
    Thanks. PS, does the end of the spring need to have a sleeve as per original etc?
    Jul 2006
    Wolverhampton
    Anyone?
    you'll need spring compressors for the front struts, torx insert bits and a 21mm box spanner or the like to undo the top nut..
    18mm socket and spanner, E18 and E20 torx socket and a tiny torx for the electrical bracket on the front struts..a pair of grips for the brakepipe spring clip iirc the top 3 strut mounts are E12
    you can transfer the spring sleeves over, superglue them to the new springs, and run some copper grease in the springpan groove.. it all helps..
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Rear shocks - E20 and E18 torx socket
    Front shocks - 18mm socket, 18mm spanner, 17mm spanner, spring compressors. There are 3 torx bolts at the top of the strut don't know the size but can check if required.
    BIG TIP - you will need a t50 torx bit and a 21mm spanner for the top of the strut to remove the spring. I had to buy a box spanner to remove the bolt. Loosen the nut ( do not remove) when the strut is still on the car.
    Try the top nut first before you remove anything as this is the only hard part.
    A trolley jack is handy to lift the suspension arms.
    Jun 2007
    in a white box
    17mm spanner is for behind the drop link to hold it as it will just spin on the 18mm socket.
    Jul 2006
    Wolverhampton
    Thanks for the advice so far. looks like I have to buy a few more tools first.
    What about wheel alignment afterwards?, will this be required?.
    My plans changed since yesterday so going to look at replacing the exhaust as well due to the Tax man sending me a cheque for £735
    P.S. Is the Haynes manual out yet?, and if so, where's the best place to get a copy?
    Sorry for all the questions, but I like to do my homework before doing the practical.
    Thanks again for your help
    Chocki.
    Planning on lots of pics and a full how to inc parts, tips etc.
    if you fit lowering springs then yes, a full 4 wheel alignment is required.. toe and camber..
    Halfords sell the haynes manual, so pick one up if you are less than 100% confident..
    Jul 2006
    Wolverhampton
    Thanks GSi.
    Redhill
    thats handy... just going to change my springs this morning.... got the eibach pro kit... for the moment, then some bilstiens B8's to follow...
    Redhill
    this might sound a silly question but how do you get the rear springs out?
  1. Going to replace my rear Shocks/Springs
    By Jonsey in forum Handling & Braking
    Last Post: 12th July 2013, 23:50
  2. springs,shocks,coilovers buying 2moro advice needed.
    By Vectra boy in forum Handling & Braking
    Last Post: 20th August 2011, 22:20
  3. New Shocks & Springs Required
    By themarbleman in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2011, 20:07
  4. advice on springs and shocks please!!!
    By delberto in forum Suspension, Wheels & Brakes
    Last Post: 10th December 2008, 09:52
  5. When should you replace shocks?
    By addyboy1982 in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2008, 11:59
