Thread: Any Plumbers on here ?
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Default Any Plumbers on here ?
    i'm just having an extension built to make room for the Baby and I'll be installing 3 new rads,
    I have a Worcester 28CDI boiler and all pipe work is currently 15mm cooper pipe,
    Question is, can I use 10mm pipe for the additional with 10mm->15mm reducers or can I use plastic pipes
    Which is best or should I stick with 15mm cooper pipe ?
    10mm cooper
    15mm cooper
    15mm plastic
    Cheers in advance Mark
    I would say its completly up to you, my last house - new build, was all 10mm plastic pipe.
    Feb 2007
    North west
    If you run the system with different sized pipes it will be harder to regulate the temp equally across the system - the smaller pipes are more restrictive and you would have to add balance valves to all the 15mm copper to equal out the flow rates. Easier to stick to 15mm IMO. You can get push fit plastic in 15mm and its really good now.
    Heating runs from manifolds with every rad getting its own supply of hot water, because of this the water will take the easiest route - you probably have gate valves already to regulate the relative flow rates between upstairs and downstairs, maybe these could be used to make it all work down to the microbore flow rates but balancing it would be a ******.
    Oct 2006
    Portsmouth
    so i could get away with 15mm platic pipe,
    will it last as long as the cooper ? just a little scared as it will be unber the floor and don't want to dig it all up in a few years
    cheers
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    the plastic stuff is called HEP2o make sure you get all the sleves and fitting's for it, idealy if it is going into concrete just lag it to help protect it
    and yes 15mm is good
    Midlands Mod Shop - NFFC.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    I've always used John Guest "Speedfit", not cheap but really good and easy to cut, join etc. Their pipe can be used in underfloor heating and buried in concrete so longevity doesn't appear to be a problem.
    http://www.johnguest.com/
    North east HQ
    for a pressureized system as the 28cdi is, john guest speedfit is the better plastic pipe. hep20 will do the job but its the way the pipes seal that makes the difference. hep20 seals using grip rings to clamp the pipe, speedfit uses pressure rings so the more pressure there is, the tighter it grips the pipe.both pipes can go under the floor and you can buy it in coils of 25,50,100mtr's so you can reduce the amount of fittings hence less chance of leaks
  1. Any plumbers in here
    By dannyjpuk in forum General Chat
    Last Post: 26th January 2012, 09:17
  2. Any plumbers on here?
    By lee gsi in forum The 'Off Topic' room
    Last Post: 30th December 2011, 23:18
  3. Plumbers
    By Daywalker in forum General Chat
    Last Post: 21st October 2010, 18:02
  4. any plumbers on here
    By neverlandandy in forum The 'Off Topic' room
    Last Post: 30th September 2009, 22:07
  5. Any plumbers here?
    By arkhan78 in forum The 'Off Topic' room
    Last Post: 15th August 2009, 00:40
