Thread: Vec C Strut Brace
    Regular Member DarrenLee's Avatar
    Shipley, West Yorkshire
    Default Vec C Strut Brace
    My strut brace arrived this morning and when I went out to fit it I got all confused about everything I am not that good when it comes to car mechanics.
    Anyone got pictures of theirs fitted or a how2??
    Thanks for any advice.
    OK went back out and had another look - it seems that they are things in the way that will stop in being attached.
    Anyone had similar issues????
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    some people have had to cut bits out.. have a search for strut brace..
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    When fitted they sit over the top of the brake fluid reservoir and the header tank,just make sure it clears the brakes by a couple of mm (if needed a couple of washers does the job).On some cars there's a nut on top of the inner wing this needs cutting off or the base of the brace needs cutting to clear,also after fitting close the bonnet carefully as it can bend the bonnet (mainly the 3.0d).
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    I hssue with an issue with a nut on the drivers side and a backet on the passenger side but 5 minutes with an angle grinder sorted it.Just ground a couple of grooves in brace then it fitted
  1. strut brace
    By sparky3865 in forum Handling & Braking
    Last Post: 8th May 2012, 13:35
  2. Strut brace on 1.8 VVT
    By 0uT1aW in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2011, 23:46
  3. Strut brace
    By Danwells72 in forum Handling & Braking
    Last Post: 2nd September 2009, 19:26
vectra c strut brace
