Results 1 to 10 of 11
Thread: Engine light showing after bumper refit
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default Engine light showing after bumper refit
    I've just removed and replaced the front bumper and now the engine light has come on.. Car is working as normal, any idea what it could be??
    @home
    Engine : 1.9 CDTi
    anyone?
    Oct 2006
    Wellingborough
    Don't you have to disconnect some kind of airflow sensor when removing the bumper? car is probably moaning about that,just restart the ignition 20 times and your light should be gone.
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by Flaninacupboard View Post
    That and the front sensors, so hopefully you are right... just checking with the experts in case I have missed something
    Nicking Ya Dinner.
    I think he means the dashboard temp readout sensor, it's in the bumper somewhere, passanger side iirc, hth.
    North West
    i nearly snap[ped mine off when i changed my front bumper
    Its a little push on connection behind the front bumper ,near the lower grill if i remember correctly
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by Silver Vectra C View Post
    yep, I left the thing off the first time around and had to take the bumper off again to put back on.
    The engine has gone out now (it was showing for a while after the air sensor went back on, so not sure what it was).
    Jan 2008
    ipswich
    Quote Originally Posted by lofty View Post
    hi mate its the out side temputure prob like normal
    I wouldn't think the outside air temp sensor is going to throw up an engine light? All it's there is to tell you the temp outside on the central display - so I thought anyway.
    Oct 2006
    Wellingborough
    Used for working out air blend on models with ECC maybe?
  1. Headlight adjustment light showing!
    By Lee_gsi in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 22:30
  2. Picture needed of clock dials showing were eml light is please?
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 21:36
  3. oil light showing
    By twaiter in forum Engine & Drivetrain
    Last Post: 11th December 2010, 11:51
  4. help! Light showing on dashboard-please read.
    By paulreg54 in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2008, 12:23
  5. help! Light showing on dashboard-please read.
    Last Post: 24th August 2008, 13:53
