Thread: problem with key
    Regular Member garvey's Avatar
    Co Durham
    Default problem with key
    When I had my other engine fitted last year they re-coded the car and now my spare key does not work. Any body have any ideas. what to do
    Did they recode the spare key at the time of the change, or only the general everyday one?
    Co Durham
    just the one with the car. I did not know the codes were being changed but they had big problem getting the car and engine liking each other
    That's probably the answer then. You need the other key recoding as well.
    yep, you just need to get them to store the other key on the car as well.. really though they should have asked for both of them..
    Co Durham
    when can i get the code from. the guy who did the recode was from newcastle. the garage got him and i do not use them any more
    the security code is on the car pass ( little creditcard sized peice of card in the cars document wallet) thats all they'll need to access the immobiliser system and program the key
    Co Durham
    my code must be different know as it used to work.
    if it doesn't work any more, getting the part numbers and serial numbers off the ecu's ( via TECH2 or a similar system) will let you obtain the correct code...
    Not the first car i've come across that the security code doesn't match any more...
    Co Durham
    the guy said it was only the 2.2 dti have problems when changing engines if I had a 2 litre would of been fine
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
