Results 1 to 2 of 2
Thread: Spanner light maybe a steering lock problem?
    NZ
    Default Spanner light maybe a steering lock problem?
    I have had a spanner light on so I went and got it read with a tech2 and it came up with a immobiliser fault. It was cleared and I got the light back as soon as the steering lock came on. I need to give the wheel a twist and turn the key at the same time if the steering lock is engaged. When this happened I got a flashing spanner thru car light. When I take the key out and try again everything is Ok and the car starts. Spanner light goes out after a second or two. Any body have any ideas? thanks
    sounds more like the immobilser pickup on the column module is playing up..that would give you the flashing light...
    the one that disappears after a few moments running is just a 'reminder' lamp and not a 'livefault' warning...so ignore that one..
  1. Car/Spanner Light Problem
    By yates in forum Engine & Drivetrain
    Last Post: 4th December 2012, 23:03
  2. Another Spanner light problem
    By robhullfury in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2011, 21:12
  3. 2.0l DTI LS estate, spanner light problem.
    By mick 1986 in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2010, 18:45
  4. Spanner Light Problem
    By levy9 in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 14:39
  5. problem car and spanner light
    By andyj in forum Engine & Drivetrain
    Last Post: 18th February 2008, 13:29
