Results 1 to 2 of 2
Thread: Rear engine oil leak?????
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Rear engine oil leak?????
    Hi all,
    I having warranty work done to my car before it runs out. So far the front n/s steering ball joint has been replaced. The rear suspension arms are going to be replaced. Worst thing is tho told them there was an oil leak and they have diagnosed it as a rear oil seal and the engine has to come out, gearbox and clutch removed. Up to two days work. Anyone have any ideas what the seal could be and would oil be getting on the clutch and therefore they should replace it. If they are taking the clutch out would it be a good practice to replace it while it is out?
    Oct 2007
    Sussex
    Hi mate,
    When my Signum went in for a dual mass flywheel replacement (same engine as yours..), they also said that the 'rear main oil seal' was leaking and needed replacement, so they did it at the same time as the 'box was off, they didn't remove the engine though as far as i know.
    They replaced my clutch with the flywheel, which wasn't caused by the oil leak.....
    Dave.
  1. gearbox and engine oil leak
    By humelis in forum Engine & Drivetrain
    Last Post: 2nd December 2011, 15:21
  2. Will play in engine mounts cause AC leak
    By Dave78 in forum Engine & Drivetrain
    Last Post: 1st March 2011, 20:23
  3. Engine oil leak
    By SNODDY70 in forum Engine & Drivetrain
    Last Post: 5th September 2010, 21:27
  4. 2001 SRi 140 V6 engine oil leak
    By Vectra 2 in forum Engine & Drivetrain
    Last Post: 12th June 2010, 08:50
  5. Engine oil leak...likely cause ?
    By bighammerfan in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2009, 15:55
vectra c cdti rear main seal
Vectra c rear main seal replacement
vectra c oil leak rear engine
