Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: HELP!!!! With LED bulbs
  1. #11
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    I used the have the pure blue LED front sidelights, which only flashed when the engine/ignition was off. They looked great at night, but they did stop after a while, I don't know how long exaclty but get in the car in the morning and they had stopped.
    I'm sure the only reason they dont work is because the computer reads the resistance of the circuit the bulb is on, i.e, if a bulb blows, there is little/no resistance therefore computer say's check 'Said' bulb.
    Im sure with LEDs because they use such a small current, the resistance is low enough to trigger the computer. Placeing a resistor in the circuit to bring the resistance back upto that of a normal bulb should solve this?
    Chris
  2. #12
    led's are not measured in watts. Its an equlivelant light output as a 5 watt lamp, if you know what I mean.
  3. #13
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    Yeah, Im aware they arn't actually 5 watts, but its the resistance the computer measures?
    Chris
  4. #14
    Regular Member hudz's Avatar
    northern ireland
    all u need is a resistor,which compensatates 4 LEDs low power /current consumption.u get them from autobulbsdirect,co,uk. 2 wires and ur sorted!
  5. #15
    Bournemouth
    OK so I'm going to order some rear/stop LEDs this morning and ask for the resistance wires. My little question is a bit basic - the bayonets on the side of the new bulb are at different heights...is that the same as the 380 standard filament bulb's?
    thanks
    Also another basic question, the resistors... do I need one per side or two per side?
  6. #16
    Bournemouth
    resistors: One per side....
    Filament height doesn't seem to affect how the bulb locates in the holder
    so order has been placed
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. Bulbs Bulbs Bulbs - non-Xenon .. Best performance?
    By Saf_789 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 08:44
  3. 80w bulbs
    By wullie-t27 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 11:00
  4. LED bulbs
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 09:47
  5. Bulbs!!!
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2007, 14:22
