Thread: Engine Management Light
    norfolk
    Default Engine Management Light
    Any Ideas? My light with a car and spanner came on yesterday with the ignition on but went out when engine started. Obviously no service centres open yesterday so had the AA out. They plugged it into their little computer which showed no faults stored?????? The bloke stated it could be the EGR clogged with some carbon deposits, anyone else ever had this?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Hi mate, never had my EGR clogged, but do you know when your service is due? It could be as simple as that. If your not to sure when its due, press the mileage reset button with the keys not in the ignition, this should tell you when it is due.
    norfolk
    Default service
    The car has only done 6500 miles from new so quite a way off yet I should think but will check
    Melbourne, Australia
    I'm still having issues with my spanner icon coming on when starting the engine. AFAIK this means that the computer has at some stage in the past observed a fault but that it is not currently present ("history codes"). Dealers seem to like explaining this as "no fault codes stored" when they really mean "no current fault codes stored".
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
how to reset engine management light on vectra c
vauxhall vectra c engine management light reset
vectra c spanner light reset australia
vectra reset engine management light
reset engine management light vectra
vauxhall vectra engine management light reset
how to reset engine management light on vectra c 2008
engine management light vectra c
