Results 1 to 10 of 21
Thread: IT help: how easy is it to....
    Regular Member Harry's Avatar
    Uxbridge, London
    Default IT help: how easy is it to....
    ...remove a hard-drive from a laptop and then get it fired up in a new 'host'.
    my laptop has finally given up the ghost...i suspect it may be a power supply issue.
    Regular Member ccsnet's Avatar
    The local dealers if driving my old Vectra
    Depends on the laptop.... normally the lappys are easy to get the drive out of ( underneath will be a pannel ).... then you'll need a 2.5-3.5 IDE adaptor ( linitx.com are good ).... then when you fire it up you have to hope the Windows Advantage cack (depending on the version & OEM setup if any ) doesnt suddnely complain.... some times it does some times it doesnt.... but its hard to say with out my hands on it....
    Hope that helps.
    Terran
    Uxbridge, London
    well it's an old Compaq Evo N610c running Windows 2000 Professional if that sheds any light on how much of a pain it will be.
    Administrator plasma's Avatar
    On the Forum
    404 Post(s)
    Engine : 150
    Mileage : 74000
    will probaby throw a wobbly when installed into a new envoiroment (sp?) due to different motherboard, sound card graphics cards etc
    Uxbridge, London
    Quote Originally Posted by plasma View Post
    so the question is, how else can i transfer what is on its hard drive to another when it's not powering up?
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    If you buy a harddrive enclosure (maplin sell them pretty cheap) then you can plug it into the usb port of another computer and retrieve any data. That should at least be pretty easy.
    Regular Member martind511's Avatar
    Swindon
    Vehicle : Audii A3 Sportback
    Trim : S Line Black Edition
    Engine : 2.0 Diesel
    Year : 2011
    Smile
    Quote Originally Posted by Harry View Post
    The Evos are easy to work on as they are aimed at the corporate market and the hard disk disk is easy to take out and you can get a USB adapter from Ebay for around £15-20 which you can plug into another computer and copy the files accross.
    Service guides etc here:
    http://h20000.www2.hp.com/bizsupport...eriesId=316664
    Regular Member cameraman's Avatar
    Leicester
    I got a hard drive usb2 adapater off e-bay for 1p recently, £4.30 delivered works a treat
    Uxbridge, London
    Quote Originally Posted by cameraman View Post
    so can you actually run programs that are stored on the hard drive, or is it just giving you access to info.
    i'm baffled by the amount of usb adaptors on ebay, how do i know which one i need?
    Uxbridge, London
    okay, so this is the hard drive that i've got:
    http://www3.toshiba.co.jp/storage/en...hdd/mk2018.htm
    is this what i need to be able to plug into another PC???
    http://cgi.ebay.co.uk/USB-2-0-to-3-5...QQcmdZViewItem
    cheers
  1. Want to fit an outside tap....is it easy?
    By wingz123 in forum General Chat
    Last Post: 30th April 2011, 21:10
  2. Easy
    By Big Knox in forum World Cup chat!
    Last Post: 19th June 2010, 19:33
  3. Tax The Easy Way
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 20:15
  4. How easy is it to fit these....
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 20:44
  5. how easy??
    By lee_eardley in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2007, 21:08
