Thread: veccy problems
    Regular Member Alec's Avatar
    Dundee
    Default veccy problems
    my dads got a 2.2 dti on a 53 plate battery keeps draining he has had 2 new batteries fitted but they keep draining now abs & traction control light is on garage said it needs new wheel bearing got one tried plugging in abs lights on dash still comes on has anybody got any ideas
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    ABS and Traction control lights suggest one of the following
    1) Wiring or plug problem
    2) module failure
    3) wheel speed sensor failure (integrated into the bearing)
    As for the battery, it might be the alternator is on the way out or an earthing fault. Get a voltage meter across the battery with the car running, it should be about 14v maybe a little less but at least 13v.
    Dundee
    cheers m8 i will pass info on
    Dundee
    it was corrosion in the plug that's attached to the chassis behind the suspension
  1. Veccy 3.0l v6 cdti problems
    By SRI_STU in forum Diesel Engine related
    Last Post: 18th November 2011, 10:32
  2. Advice please on my veccy / problems with manifold
    By eraser2002 in forum Engine & Drivetrain
    Last Post: 7th June 2010, 07:06
  3. More problems with my Veccy
    By jonnynufc in forum Engine & Drivetrain
    Last Post: 9th March 2010, 14:13
  4. Veccy brake problems
    By toughmat in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd June 2009, 16:41
  5. Veccy brake problems
    By toughmat in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2009, 19:49
