Thread: 2.0 DTi
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Default 2.0 DTi
    Can anyone help?
    My mate has a 2.0 DTi Vectra-B and when he gets to around 15-20 litres left in the tank, it just stops and won't start until it's filled up again.
    Has anyone any ideas?
    Cheers.
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Mileage : 198,500
    Has he checked that there actually is fuel in the tank or is he going on the gauge reading?
    Regular Member rob1964bike's Avatar
    Elgin Scotland
    Good point could be faulty gauge
    On another planet
    Engine : 2.0
    Nope, there's fuel in the tank, the guage says there's fuel in too.
    And when he fills it up he can only put another 30odd litres in.
    So the guage isn't faulty.
    Seems to be some sort of bizzare problem
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    unless the pick up pipe/float in the tank has broken, there for when the fuel level drops below the pipe it wont feed the bump
    Regular Member EURO G's Avatar
    n ireland
    On another planet
    Engine : 2.0
    Cheers Guys... The problem seems to be the fuel return pipe. Cracked and brittle. Taping the affected piece of the pipe up sorts the problem. So he's off to Helfrauds tommorow for some pipe (if they sell it) and i'm going over with my toolkit and jack etc etc.
    Administrator plasma's Avatar
    On the Forum
    367 Post(s)
    Engine : 150
    Mileage : 74000
    if its the woven type and you decide to change all of it including the bits to the injectors expect them not to come off without a fight and all expect them to snap flush with the engine block. You'll have to pick the remaining bits out with a very small screwdriver/pick. Did this a cpl of weeks ago...
    On another planet
    Engine : 2.0
    Cheers PLASMA. From what my mate is telling me, it sounds like part of the pipe and not the seals. (hence the tape working)
    If the seals do look dodgy, then i won't touch it, until he can get the parts from VX etc.
    I was thinking though, it's probably better to replace the pipe and the seals at the same time. So i'll have a look tommorow and see for myself.
    Thanks for the advice (tooth pick at the ready)
    halfords do sell the pipe, its coiled up with two jubile clips on black cardboard
