Results 1 to 10 of 14
Thread: rear of car moves sideways/skips
    Regular Member PeteRs's Avatar
    here or there
    Default rear of car moves sideways/skips
    ok got a strange thing happening on rough roads in particular earlier today i had choice but to go over a sunken manhole well the rear of the car went sideways after going over the manhole i have noticed this over past few days but thought i was imagining it but it definitley moves or skips sideways i recently lowered the car but left the original sri shocks in as they were only 2 month old is lowering it 45mm causing the problem as the shocks are too long or is there something else likely to be the culprit thanks
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    check your rear tyres m8 as you might have one out of shape
    here or there
    there new tyres on it does feel as though it moves to the offside
    they could be out of shape even if they are new or it could be a rear bush gone still worth getting it checked out before things get worse
    here or there
    had wheels/tyres checked there ok bushes also seem ok so thinking about swapping shocks
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Shock absorbers are knackered mate, without doubt!
    Standard GM Shocks are crap, Vauxhall only waranty them for something like 5000 miles from the factory!
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    yep..if its bouncing and skipping its deffo the shocks... try proven products for bilstein b4's instead of vx ones..(£73 deliverd)
    or u could also get performance shocks like the b6's depending on your budget..
    here or there
    they were replaced by vauxhall under warranty in december 2007 only done 8oo miles since but cant see anything else causing the problem unless its cos i lowered it & the shocks are'nt working right now ta
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Did you get the suspension re-alligned after dropping it?. The camber may well be out loads!.
    Portadown, N.I.
    Quote Originally Posted by PeteRs View Post
    I had the very same problem with my Vec stepping out at the back, it turned out to be the Rear Upper Control Arms that were shot. £35+vat ea and only 2 torx bolts on each arm, an easy job to do.
    Tim
  1. sideways sunday car culture
    By peadar in forum Northern Ireland (RO - Vacant)
    Last Post: 23rd February 2013, 13:01
  2. Fifth Gear moves to Discovery
    By Big Dave in forum General Motoring Chat
    Last Post: 6th September 2012, 01:40
  3. Sideways?
    By Lao in forum The 'Off Topic' room
    Last Post: 17th March 2011, 13:23
  4. Vectra sri 150 satnav cd player skips on cdr's and gets hot after a couple hours
    By rollercoaster63 in forum Electrical & ICE (including SatNav)
    Last Post: 16th July 2010, 22:04
  5. Sat Nav in 55 Vectra New shape skips
    Last Post: 21st August 2008, 12:49
