Thread: The Loudest...
    Stoke on Trent
    Default The Loudest...
    Has anyone had any dealings with these? Or heard any of there products in use?
    http://www.theloudest.co.uk/
    Some of there products seem impressive, 2000 watt 6x9s with 350 watt RMS!!! And there prices are very reasonable.
    Just wondering if theyre legit or if there products are crap.
    Thanks,
    Gaz.
    Regular Member siross's Avatar
    Oct 2007
    The Loudest overestimate their amps by a long way but by no means are they bad, they're not going to set the world alight but for the price you can't go wrong.
    By the way, 6x9s will be recieving power (watts) from an amp, they won't be producing it, so they're ratings dont mean much, only what power they can handle.
    Regular Member Whippy's Avatar
    Oct 2007
    wirral
    Quote Originally Posted by siross View Post
    and even then they're pushing it.
    it'll sound crap before it reaches those levels.
    buy decent kit 2nd hand and you'll not be dissapointed.
    i had a set of 90w rms DLS speakers in the old motor and was feeding them 220w rms daily.
    they never let me down once.
    Stoke on Trent
    can you reccomend any makes then mate? I might give just the 6x9s a try from 'the loudest' and run them off my sub/amp what ive got at the moment, just see how they are. There 1000 watt ones are only 40 quid.
    Dont wanna spend 200 quid though if its gonna be crap.
    cheers
    Gaz
    Oct 2007
    the 1000 watts in terms of the 6x9s means ****** all. It means that at one given time in perfect conditions an amp may have given them 1000 watts perfectly clean power for a nanosecond and they didnt break.
    In my opinion unless you want to spend money on your passengers, 6x9s are a waste of time, spend the money on better components/amps and sound deadening.
    All my opinion of course, you may like rear fill, if so, go with some 6x9s but i would say listen to a well set up front end first
    Regular Member coopster's Avatar
    ireland
    dont go near them mate i spent over 1000pounds on sub and them 2000watt speakers all crap the 4000w amp (yer right) hooked it up to there 4000w sub works fine low rated turned it up for a sound off and the thing started to smoke. also the speakers cam apart the conection had to be soildered. really save you money sorry i did'nt go for something better. hope this helps
