Results 1 to 10 of 15
Thread: Spanner Light Help
    Regular Member eaglepva's Avatar
    Up North
    Default Spanner Light Help
    Hi
    Went out in me siggy yesterday floggin it down the a19 when the spanner light came on and the car went into safe mode. Read the handbook and said to restart the car which i did and it seemed fine but it done it again today. The car is running fine but seems to be a bit down on power when pulling away from round abouts etc, the car is a 2.0dti siggy.
    Any ideas?
    Thanks Ashley.
    Nicking Ya Dinner.
    Mass air meter, black cylinder between airbox and engine, might not be this, but that is what happens when it goes.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Could also be the boost sensor needs cleaning, exactly what happened on my 2.2DTi.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    At the end of the day, you may get lots of suggestions as to what it MIGHT be. The only true way of knowing is to get the fault code that will be stored in the ECM read. If you're an AA or RAC member, they might be able to come out and read the FC for you (you will need to word the phone call well though). At least then it will guide you to what the trouble is, and take away most of the 'guess work'. OR you could take it to a garage to get the fault read - but that will cost you some cash....
    I'm sure it's not terminal, just a hiccup that will easily be resolved.
    Up North
    Just been out havin another look under bonnet and found that 1 of the rubber pipes their are 4 of them and they are white, where they push onto summit 1 is split could this be the fault ive put it back on and put sum tape on it and now the car seems back to normal, i took a picture on me phone but it wont connect to me laptop at the moment so cant post the pic up.
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Was there any liquid around it, fuel specifically? There are four fuel return pipes but they usually just leak air in, I've not heard of them splitting. More common are boost lines splitting, get someone to rev it while you hold you hand near it to see if any air comes out. Might even be a vacuum line but without seeing it who knows?
    Important to note though, unless the fault occurs for more than 30 seconds that can might not record a fault code. So if it happens again, pull over and leave it running for over 30 seconds. Then get the code read out.
    Up North
    Picture of the pipe that has split i have taped it up using white insulating tape. Anybody know the part number to get a replacment part. And if this could be causing the spanner light.
    Thanks for your help much appreciated.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    If that is the split pipe it looks like a vacuum pipe will almost certainly bethe cause can you take a close up pic covering the area you have highlighted only.
    3.2 v6 Signum and loving it
    Up North
    Just taken these close up pic sorry if they aint very good but was holding bonnet as its blowing a gale lol.
    Can take a pic from a different angle if that would help.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Going from what you are saying. If it is the rubber pipe that is split auto shops sell lenghts of this. Take it off go to the shop and ask for a piece of pipe that size swap the pipes and refit. You may have to use a small jubilee clip to secure the new rubber. Should work and will not cost much, couple of pounds maybe.
    I can't find the part on the parts list I have, but I have only just acquired that so will probably be looking in the wrong place for it.
    I will give you a shout if I find it.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
