Thread: stuttering uphill
    Regular Member ALD's Avatar
    South Lanarkshire
    Default stuttering uphill
    Anyone experienced this, I've only had the car 4 weeks, and its happened twice now, i've now realised it only happens on an incline when the car is not driven hard and happens around 30-35mph in 3rd & 4th gear.
    already been to the dealers with no success, probably because it won't do it everytime its driven, and no fault code appeared.
    The only thing I can think of is the fuel pump or something, any thoughts what could cause this?
    Regular Member Karl's Avatar
    Sunderland
    what revs are you at when it stutters?
    South Lanarkshire
    from memory its between 2k and 3k, will need to double check next time it happens
    Regular Member Dodger's Avatar
    West Midlands
    I get same when in cruise control is on, in fourth gear going up an incline, the car seems to keep surging faster then backs off again. I think it's only minor though.
    Sunderland
    IIRC that's when the turbo is just starting to come online in a 2.0T aint it? Might be that its JUST coming on then off. I take it you can cleanly accelerate through this? (gently if you know what I mean) and that its only there when sitting at a constant speed?
    South Lanarkshire
    Quote Originally Posted by Karl View Post
    thats right, when I'm just at a constant speed it happens.
    so basically it might not be specific to my car, its just at the point of the turbo kicking in.
    Feb 2011
    Plymouth, Devon
    Trim : SRi soon VXD
    Engine : 1.9 CDTi
    Year : 07
    Mileage : 65k
    ive got this problem but all the time!!! well i say all the time its mor 70% of the time. cruising on the motorway i use cruise control and sometimes its fine and works normally then 70% of the time it surges on and off the power all the time.... uphill, downhill, flat.
    Ive got GSi so 3.2 v6..... no turbo range to be sitting on the edge of.
    any idea's???
  1. Loss of Power when going uphill
    By DonDedders in forum Engine & Drivetrain
    Last Post: 27th August 2014, 12:21
  2. 1.9CDTI 120 - Stalling on mways uphill...
    By RichieClyde in forum Engine & Drivetrain
    Last Post: 30th August 2013, 21:51
  3. Cdti stuttering
    By gtirobbie in forum Engine & Drivetrain
    Last Post: 23rd June 2012, 16:38
  4. Car with spanner on when uphill or downhill??
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 11th June 2012, 00:49
  5. Uphill Race
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2007, 09:49
