Thread: 4,000 rpm engine stutter
    Jun 2006
    scotland/ aberdeen
    Exclamation 4,000 rpm engine stutter
    55 plate 1.9 cdti 16v, 58k on the clock, always vx dealer serviced
    have had some problems with engine management light in the past which the the dealer has fixed, took 3 attempts though said they had to relplace the engine management unit & the EGR valve.
    had the car back in for engine management light again last week, got it back with a fault, at 4,000ish rpm the engine dies for a split second then carries on, change gear and take it up to around 4,000 rpm same again, fault comes and goes.
    Put it back in with the dealer they fitted a exhaust gasket road tested it and said it was sorted, i drove it 5 miles from the dealer still had the same problem, gave it back to them.
    anyone had a similar type of fault
    cheers
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    I had this sort of problem on my 53 plate focus (dont shoot me guys) TDCi... Ford were shyte at trying to fix it so I ended up selling it.
    If the Vx dealer is trying to fix the problem, keep guiding them in the right direction.
    Will look at posible fixes for you mate.
    Andrew
    May 2007
    Have they checked the MAF??
    Also, check the air box, in some cases, the filter has been defective and has distorted itself causing a partial blockage. This can give (apparently) the symptoms of a lack of power as you describe....
    Looking still for other potential problems / causes
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Is it petrol or diesel and do you have the engine management light on now?
    Jun 2006
    scotland/ aberdeen
    Default 4000 rpm stutter rap
    cheers for that, dealer still has car untill monday will let you know the outcome
    May 2007
    Do what I did with Ford, take them suggestions from the Forums.... but do what I didnt do - make sure they actually chech your suggestions.... and ask Mark ( GSI 3.2) - he is the font of all knowledge!!
    Andrew
    Jun 2006
    scotland/ aberdeen
    Angry
    1.9 cdti 16v,
    they have fixed the light but put this fault on it
    the dealer has it back untill monday
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    egr valve ???????
    Midlands Mod Shop - NFFC.
    May 2007
    Quote Originally Posted by ditchp View Post
    egr valve ???????
    was thinking that... but there is another thread in existence..... cast your eyes over my suggestions....
    Jun 2006
    scotland/ aberdeen
    this fault was on the car after they fitted a new EGR valve for the engine management light fault
  1. Engine stutter at 70mph.
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd December 2011, 09:56
  2. DTI Engine Stutter
    By keithtinman in forum Engine & Drivetrain
    Last Post: 29th July 2011, 17:11
  3. SRI 150 CDTI engine stutter
    By sri150 in forum Engine & Drivetrain
    Last Post: 12th July 2010, 20:59
  4. engine stutter
    By paul wingnut in forum Engine & Drivetrain
    Last Post: 16th December 2009, 21:07
  5. Slight engine stutter
    By frazejax in forum Engine & Drivetrain
    Last Post: 25th August 2008, 17:07
