Results 1 to 10 of 15
Thread: Rear Alignment
    Regular Member mshaw's Avatar
    North Wales
    Default Rear Alignment
    Has anyone here experienced uneven tyre wear on the rear wheels, i just had to get my tyres changed as the inside half of both rears were mishapen and unevenly worn. Found a garage with 4 Wheel Allignment gonna get it checked next week.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    yeah the vec has an issue with negative camber and if they arent aligned properly that will just make the wear problem worse.
    North Wales
    really, i wasnt aware of that, i will deffo make an effort to get it looked at then
    when u have it aligned ask them to do the camber aswell.
    North Wales
    I am going to fit some SRI Springs to this it might be worth me fitting them first. Then get it all checked over after
    Regular Member EURO G's Avatar
    n ireland
    yeah get springs in first if not them when you fit springs that will throw the lignment out again,if its really ad you can get camber adjustment bolts
    use one of the guys from here... www.alignmycar.co.uk
    North Wales
    Nice one mate, cheers for that, the place i actually had it booked in at was top of the list on that website, does the voucher actually get you 5% off
    never tried the voucher.. but if you don't ask......
    Feb 2006
    Dorset
    Cool , i need to get the MX set up when its lowered , the double wishbone suspension goes in all directions on that thing
    Can you do much in the way of alignment on the vectras rear ? my wheels are starting to look a bit well angled like /-----\ and the passenger front oddly
  1. 4 wheel alignment
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 21:42
  2. Rear Wheel Alignment
    By JDX-SRI in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2010, 21:28
  3. Trying to Get Alignment Done
    By Jezzy in forum General Chat
    Last Post: 3rd March 2010, 12:49
  4. would a failed shock absorber cause bad alignment on the rear?
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2007, 10:56
  5. Headlight alignment
    By The Gas Man in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2006, 18:50
2007 opel vauxhall rear wheel allignment
