Thread: 3.2 auto gearbox oil change
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default 3.2 auto gearbox oil change
    Hi peeps,
    As I don't know what model auto box I've got on my 2002 GSi, it looks like, according to the owners manual, that I either change the oil at 40 or 60k.
    Either way, I'm approaching 60k now and the owners manual makes no reference to capacity or grade.
    Also, how do you actually change the oil?
    So if anyone can help me out with capacity, grade and a "How 2", I'd really appreciate it.
    Many thanks.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Further to my thread above, I managed to locate the auto box dip stick buried away down below.
    The oil "looks" Ok but | checked the level with a cold engine.
    There are two marks on the dipstick, one for "hot", and below, one for "cold". The oil level in my box is at the hot mark (high level) even with a cold engine.
    Now the worrying bit - it says on the dipstick "DO NOT OVERFILL". I'm guessing mine IS overfilled given what I found above.
    Now I'm getting desparate for a reply to my original thread.
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    According to Autodata Auto Transmission drain and refill is 3.0 to 3.5 litres for a Vectra C 3.2 2002, Vauxhall oil part number 93160393
    Autodata also suggests that the automatic transmission oil change should be every 40,000 mile on transmission types AF 13/17/20/22/23/33 only.
    HTH
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Cheers, TFT.
    Nov 2005
    Edinburgh
    I'm no mechanical guru, but I have a vague recollection (from an AW web-site?) that the type of transmission fluid is highly specific for this gearbox due to the nature of operation of the lock-up clutch. Make sure you get exactly the correct type when changing the fluid.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Out of curiosity, what type of manual gearbox is in the GSI?
    F28? F35? F40?, and is it wide ratio or short?
    Gazza4
  1. Auto Gearbox Fluid Change
    By Homer in forum Engine & Drivetrain
    Last Post: 15th November 2012, 10:50
  2. Auto Gearbox Oil Change
    By rocket999 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 19:46
  3. Auto Gearbox Oil Change -Special Oil?
    Last Post: 28th July 2010, 18:59
  4. change gearbox oil on auto signum
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2010, 15:41
  5. Auto gearbox oil change
    By Elevonic in forum Engine & Drivetrain
    Last Post: 28th August 2007, 12:45
vectra c 3.2 automatic
gear box oil change vectra 3.2vectra c transmission fluid t ivvauxhall vectra c automatic gearbox oil dipstickAutomatic gearbox opel vectra 3 2how to check oil level transmission opel signum 3.2signum 3.2 automatic transmission oilwhat type of gear box.oil 3.2 vectrainsignia automatic gearbox oil change
