Thread: Noise on clutch
    Regular Member PeteRs's Avatar
    here or there
    Default Noise on clutch
    As i put the clutch down it makes a rattling sound but only for a split second once past the intial point its quiet should i worry or not theres no other problem with clutch thanks
    Regular Member Finty's Avatar
    Jan 2006
    Ireland
    Mine does that as well. Its been like that for ages and doesn't seem to causing any problems...interested to hear some responses though
    here or there
    mines just started if yours been like it for a while maybe its not serious then
    Jan 2006
    Ireland
    Hopefully not Its been like that for about 25k klms or so
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    It's the Dreaded Dual Mass Flywheel Issue im afraid.
    Simple description is -
    It consists of two flywheels, Centre & Outer, The centre one is cushioned from the outer. The dampers wear & the Flywheels chatter against each other. It will only get worse im afriad, My take years , may take months
    Dean
    Jan 2006
    Ireland
    Quote Originally Posted by DeanF View Post
    Dean
    More good news. Hopefully it'll last another 9 months then its someones elses problem.
    When it finally fails is it a loss of clutch?
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    yup, clutch and flywheel - what was it to fix guys??? £1300 ish??
    Jan 2006
    Ireland
    Quote Originally Posted by andrew the bobby View Post
    £1300!!!! ******
    €1700. It'll be parked up on the dealers fore court with scrap written on it before I'd pay that. Roll on that new 320d it can't come soon enough!!!
  1. Clutch noise
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 29th April 2011, 10:25
  2. Clutch noise
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 1st July 2010, 08:10
  3. noise on clutch
    By gasrac in forum Engine & Drivetrain
    Last Post: 24th May 2009, 18:39
  4. Clutch noise?
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2009, 18:20
  5. Clutch Noise / Kit
    By robzc in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 08:11
