Thread: Switch
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Default Switch
    Since I've had the car - Year in January - I have received this warning tonight) and about 5-6 other times:
    'Check Brake Light Switch'
    I was once fortunate and it happened when I was reversing into a parking space where I could see the brake lights in my mirrors and the message popped up but the lights were all working.
    Is the message telling me there is a fault with the switch and that it should be looked at or is it telling me that the car itself is performing a check?
    Like I see say it only pops up now and then, but don't want to be rear ended because the switch never worked to turn on my brake lights!!
    Has anyone else suffered this?
    Any help would be most appreciated
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Full Member Big Sig's Avatar
    Remove all the bulbs and double check them. Not sure if you know but the vec will use another bulb if a brake light fails, so it may look like they are all working. While you have them out clean all the terminals incase its a bad connection in there. hth
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Wouldn't that throw on the bulb failure though, and not switch issue?
    Does the switch need resetting (you'll have to do a search on here about it), something to do with the plunger position.
    Quote Originally Posted by Ste View Post
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. t/c switch help
    By kitchcav in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 18:02
