Thread: Changing plugs on 1.8
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Changing plugs on 1.8
    Not used to having the plugs hidden from me at the back of the engine, under some sort of bar, can anyone tell me how to get at them? Is there a how to?
    Sorry to be so basic, but last car had the plugs in the traditional place, at the front, pull off the leads, straight in with the socket, no messing!
    Yes I am old!!!!!!
    Oct 2007
    south wales
    Default little help please?!?!?
    Anyone out there? is there life on planet vec?
    Regular Member simac's Avatar
    Wirral
    You have to move the "bar" which is the coil pack and sits on the plugs. It's attached by some torx screws which you have to remove (4 IIRC).
    Then the plugs can be seen, you'll need an extension bar as the plugs are quite recessed into the engine.
    HTH
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    They are on the top of the engine too, under the main cover. As Simac says, remove the coil pack (unplug, unbolt and pull upwards off all 4 plugs) then unscrew each plug with an extension bar on the socket.
    If the rubber of the plug socket is worn and won't lift the plugs out, simply fully loosen all the plugs and then push the coil pack back into place and lift all the plugs out together.
    Refit is as easy as removal, but makes sure the coil pack is firmly attached to the plugs
    Wirral
    Quote Originally Posted by Ste View Post
    Good tip, i'll remember that !
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    And it does work too, my plug socket has seen better days... but it's not a problem when plug are inclined, or are to shallow enough to get to.
  1. Changing spark plugs 2.8T
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 14th June 2012, 12:28
  2. Changing Spark Plugs
    By Chris SRi in forum Vectra C / Signum Troubleshooting
    Last Post: 7th October 2011, 21:50
  3. changing plugs
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2008, 20:23
