Results 1 to 10 of 17
Thread: Mixing oil?
    Regular Member grumpano's Avatar
    North West
    Default Mixing oil?
    When i took my car for its first service i had the 1 year service done.I thought that VX would use fully synthetic oil so i bought some for topping up,which i have not had to do yet If semi synthetic was used is it ok to top up with fully synthetic? It says Visco 3000 on my service receipt.
    as far as im aware its perfectly ok to mix fully and semi
    North West
    Cheers Phil.Does anybody know if Visco 3000 is fully or semi?
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    From checking Bp site if vaux have used visco 3000 semi synthetic oil it is the wrong oil for your car as it is 15w40, I would be going back to Vaux and asking some questions, check out this link
    Sec from BP site for your car is: http://www.ew2.lubesinfo.com/framese...=1204&langid=1
    Make VAUXHALL
    Model Vectra 1.9 CDTi (88/110kW)
    Engine DT
    Year 2004-
    Application Recommendation Capacity (ltr)
    Engine (DT) VISCO 7000-GM 0W-30 (n) 4.3
    Manual transmission USE ONLY MANUFACTURER RECOMMENDED FLUID 1.6 / 1.9
    Automatic Transmission
    Differential From Gearbox
    Coolant REFER TO TECHNICAL 7.5
    Brake Fluid BP BRAKE & CLUTCH FLUID
    Wheel Bearings Recommendation ENERGREASE LCX 222
    Alternative ENERGREASE LS-EP 2
    Hide Notes Oil Change Intervals
    Hope this helps
    North West
    Oh noooooooooooooooo
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Kill the cheap scates! Or at least ask for the cost of oil and filter back.
    The garage I bought my CDTI from told me to use a 10W40 oil which I though was cr*p and it actually says on the Vx web site to use a 5W30.
    If the garage used anything else they are trying o save themselves money and you should kick their teeth in for trying to rec your car.
    As for mixing, semi synthetic means reworked mineral oil, so you can mix them but you won't get the benifits of a fully synthetic because the mineral oil will strip it off the walls again.
    Also I would not recomend mixing oils of greatly diffrent viscosities, they may seperate.
    Check this out:
    Vauxhall recomended engine oils
    North West
    I had the car seviced 8,000 miles ago!!
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Have you noticed a drop in fuel economy and power?
    Dec 2005
    Go back to dealers and complain you should get a free oil change as they have not followed GM recommended guidelines for your car. The dealer has used cheaper oil, but the oil used is not even an alternative option as it is too thick when cold so will not provide high quality cold start protection. You could always contact GM direct and complain.
    North West
    Yes i have noticed a drop in fuel economy,Do you know the number for GM customer complaints?
  1. MP3 Mixing
    By Aidi in forum The 'Off Topic' room
    Last Post: 18th January 2011, 21:34
  2. Anyone else into mixing or Djing?
    By TimTay in forum General Chat
    Last Post: 27th December 2010, 20:25
  3. Mixing oil grades
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2008, 20:51
  4. Mixing Polishes.
    By FIL 4822 in forum Detailing and Car Care Discussion
    Last Post: 19th March 2008, 21:00
  5. Mixing tyre sizes
    By JuzzyD in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2007, 17:45
