Thread: will it be easy to install
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Default will it be easy to install
    would it be possible to fit this
    http://cgi.ebay.co.uk/Vauxhall-Vectr...QQcmdZViewItem
    into my dti ls model and would i need anything else to install it cheers for any help
    Regular Member shan's Avatar
    They say.
    Vauxhall Vectra C CD70 navi sat nav + LCD monitor Vauxhall Vectra C CD70 navi sat nav + LCD monitor, it will NOT come with a security code.
    No security code. It should have been Tech 2'd out of the car and then it needs tech 2ing into your car. So it's nothing more than a piece of junk if it's not been done.
    I'd email him and ask, it's worth a try.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    the code, the sat nav disk,
    Have you removed your old display and looked at the connector? It is probably different to this one. Not sure about wiring either.
    Anyone with TIS should be able to see if the wiring is different. Maybe ask at your local dealer if it;s compatible? ?
    if it has been tech2 out, will it be a straight forward fit or is there more to it
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You will need the GPS aerial as well
    Quote Originally Posted by Ste View Post
    Ste i beleive they do not have a code. It has to tech 2'd out of the car for it to be tech 2e'd into another car. Thus no need for a code.
    Glynn i would think it will go in no problem . But i'm sure somebody will be along to confirm. No sat nav disk it not a problem they are quite cheap on ebay.
    Quote Originally Posted by shan View Post
    thanks for your help shan, i have just emailed the seller to see if has been tech 2, and told him it wont work in another car if it hasn't
    Quote Originally Posted by glynn View Post
    Like i say it's worth a try.
    But with a 99p starting bid i'd put money on it it's not. These things are 1200 quid from VX.
  1. is it easy to install rear electric windows
    By P11CRG in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2012, 20:19
  2. Are Coil springs relitively easy to install?
    By Deanie in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2010, 19:15
  3. easy one?
    By booker413 in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2010, 02:13
  4. how easy is it....
    By john1 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 09:19
  5. Tax The Easy Way
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 20:15
