Thread: rear wheel knocking
    Regular Member Flyingdutchman's Avatar
    W Sussex
    Default rear wheel knocking
    just been out in the vec, and have noticed a knocking noice coming from the rear drivers side wheel. Had a tug of said wheel and it moved although it was only a nat's whisker of movement it did move and make the knocking noice.
    Any ideas? please be gentle as the road tax is due
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    loose wheel nuts? Bearings?
    derby
    i would tighten the nuts first if that doesnt solve it try the hub bearing
    W Sussex
    No nuts are fine, maybe bearings?
    either loose road wheel ( has been known) or it needs a new top arm as the bushes are worn..
    you need to try rocking it top and bottom and side to side.. each movement has it's own fault meaning..
    W Sussex
    Yes I can only rock it from top to bottom and not side to side.
    top arm will need replacing...around £35 for a replacement part from your local motor factors...takes about 1/2 an hour to change..
    W Sussex
    Thanks Gsi 3.2 yet again you have come up trumps if I was wearing a hat I would tip it your way.
  1. knocking from back wheel
    By Linz-t- in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2012, 17:53
  2. Knocking noise from Front Wheel
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 08:14
  3. knocking on my NSF wheel
    By myelite150 in forum Suspension, Wheels & Brakes
    Last Post: 19th May 2010, 21:10
  4. vectra c rear wheel knocking
    By sparks in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 21:05
  5. Loud knocking from Left Rear Wheel
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2008, 18:46
