Results 1 to 10 of 11
Thread: What is the best engine oil for 1.9 cdti?
    Regular Member Nev's Avatar
    Gosport - Hampshire
    confused What is the best engine oil for 1.9 cdti?
    As the title suggests, what's the best oil to use? My local VX dealer says fully synth 0/30, although this can't be bought anywhere can it? Anyone know the next best equivilant?
    Cheers,
    Nev.
    use VX's 5W30 fully synthetic..
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    I reckon the recommended oil is longlife 5w-30 which is what I run in mine, although you will never harm it by changing it more regularly in my opinion. Longlife is fully synthetic Service Classification: ACEA A3 B3 B4 API SL CF Meets requirements of: OPEL B 040 2095 (GMLL-A-025), OPEL B 040 2098 (GMLL-B-025)
    Make VAUXHALL
    Model Vectra 1.9 CDTI 16V, -Auto , -SRi (Vectra C - Z19DTH - 110kW)
    Engine DT
    Year 2005-
    Application Recommendation Capacity (ltr)
    Engine (DT) LONGLIFE (m,u) 4.3
    Manual Transmission Refer to Owners Handbook 3.2
    Automatic Transmission (q,r) 7 / 7.2
    Differential From Gearbox
    Coolant (50%) XSTREAM RED 7.5
    Brake Fluid DOT 4 ESP
    Power Steering CHF 11S
    Lubricant / Capacity Notes
    m.ECOService (1): SYNER-G / PREMIUM ULTRA LITE / ULTRA LITE (viscosity must be 30 or greater for petrol and 40 or greater for diesel). LONGLIFE also suitable depending on model
    u.Engine oil viscosity recommendations prior to 2001:
    -20C to above 40C, 10W-40/10W-50/10W-60; -15C to above 40C, 15W-40/15W-50; -10C to above 40C, 20W-40/20W-50. Monograde: -10C to 15C, 20W-20; 0C to above 40C, 30. 'Improved Lubricity'/ synthetic or semi-synthetic oils': below -30C to above 40C, 0W-30/0W-40/5W-30/5W-40/5W-50; -20C to above 40C, 10W-30/10W-40
    q.Automatic Transmission, AF23/AF33: Refer to Owners Handbook
    r.Automatic Transmission, AF40: Refer to Owners Handbook
    SYNER-G is 5w-40
    PREMIUM ULTRA LITE is 5w-40
    ULTRA LITE is 5w-40
    LONGIFE is 5w-30
    HTH, sorry if its a bit long winded
    you have to use VX's oil if you have a DPF as the sulphur content is vital to the survival of the DPF..
    Gosport - Hampshire
    confused
    OoooKay -
    1) what's a 'DPF'?
    2) where can i get a maintenance manual from for when i do my own stuff
    and...
    3) are dual mass flywheels a real problem when they decide to give up and 'break-down'.
    I only ask as i have a very high mileage motor - 98,000(!) although it does have a complete main dealer service history with print outs of each of the services and inspections etc. It was a motorway mile munching company car. Doesn't appear to have been thrashed (no major stone chips where you would normally find them) and she has been really well looked after - shes even got the bigger alloys which haven't even been kerbed.
    Nev
    Belfast
    I'm using Comma's Long-Life 5W30 which has all the Vauxhall approvals etc. Was about £22 for 5 litres.
    98k isn't high milage if it's motorway work.
    Gosport - Hampshire
    Cheers ZS!
    My local dealer said they only sell in 1ltr bottles at 12 a go!
    I guess the oil change is straight forward? It's the first time i've worked on a modern car. All others i've worked on have been pre '94.
    Cheers,
    Nev
    Regular Member installer's Avatar
    Nottingham
    is this true?
    My mate thats a mechanic said use comma 5w-30w is vxl spec and is half the price of vxl stuff.
    I said can`t cos got DPF and doesn`t like sulphur.VXL`s brew is supposed to be for DPF cars.
    He said comma should be as it`s made to vxl`s spec.
    So any clarification - apart from I have use vxl oil at twice the price for my DPF?
    11 Post(s)
    Quote Originally Posted by Nev View Post
    OoooKay -
    1) what's a 'DPF'?
    Diesel Particulate Filter.
    Gosport - Hampshire
    oh ok, so where is that located and what does it do - is it part of the exhaust system? And how is it affected by the grade of oil?
    Cheers,
    Nev.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. V6 CDTi Engine Oil
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2012, 12:28
  3. cdti engine pic
    By jofenan in forum Engine & Drivetrain
    Last Post: 16th January 2011, 23:36
  4. Hi, 1.9 CDTi, which engine?
    By Craigus in forum Introduce yourself.
    Last Post: 1st January 2010, 11:09
  5. 1.9 CDTI 150 Engine
    By Gavin in forum Engine & Drivetrain
    Last Post: 30th September 2005, 17:09
triple qx oil vectra c
vauxhall vectra 2009 1.9 cdti best engine oil
af40 automatic gearbox mechanic say put 5w30 engine oil
comma car oil 5w30 Belfast
z19dth engine oil
best oil for astra 1.9 cdti
best oil for 1.9 cdti
Which oil for Vauxhall astra 1.9 cdti
vauxhall signum cdti longlife oil review
