Results 1 to 10 of 17
Thread: 2004 - Creaking from front
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default 2004 - Creaking from front
    Hi
    Looking for any pointers.Car driving fine.However, when I go over any speed bumps there is a loud creaking from the front (somewhere).I have not been under the car yet to check, but anything obvious I should look at.Car on original shocks/springs and is at approx 47K on the clock.
    Full Member Big Sig's Avatar
    Anti roll bar bushes
    deffo the bushes..easy to change at home
    Apr 2006
    Inverclyde
    Thanks for the tip.Where is the best place to get new ones? Dealers?
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Mine is sometimes doing this... is there any chance of a simple how 2 anyone..
    Or even a few pointers
    Any help will help?? you know what i mean.
    Regular Member Woodsta's Avatar
    May 2006
    Kent
    Just got round to changing mine earlier along with the drop link rods.
    No more creaking and drives better!
    Both bushes cost about £5, and both drop links were £25 from vx
    Check which size roll bar bushes you need?
    All completed in about an hour.
    I think there is a how 2 or description somewhere on here.
    And lastly you can use a 10mm ring spanner for the torx head on the roll bar bushes!!
    Woodsta
    Apr 2006
    Inverclyde
    Apologies for sounding as if I know 'nowt' about cars.........are the bushes accessed from underneath the front of the car or from in the engine.I always assumed the anti-roll bar was across the top of the engine,but after having a quick look in,I am puzzled as to its whereabouts.
    May 2006
    Kent
    The anti roll bar sits down the bottom of the engine bay above the chassis.
    Turn your wheels fully to the left, look inside the front off side (drivers side) wheel,.
    You will see your wishbone that mounts to the chassis and the hub that your brake discs are attached to.
    Just above the wishbone your antiroll bar will bend over and to the right to a vertical drop link (straight bar with ball joints on)
    Follow the roll bar into the engine bay and you will see the anti roll bar bush, its a small rubber mount approx 1.5" in size and held in place by 2 torx bolts and a metal cup.
    Its in the same place both sides.
    Hope that helps (and makes sence)?
    Woodsta
    Regular Member corman's Avatar
    Mar 2007
    hexham
    so do you need to jack the car up or can you do them from a set of ramps?
    does everything stay in place as you replace each part?
    about to replace my bushes/droplinks this weekend
  1. creaking front end
    By Swedge in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2012, 11:15
  2. creaking from the front
    Last Post: 11th October 2009, 19:24
  3. creaking from front end
    By tony whin in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2009, 21:53
  4. Creaking from front
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 8th December 2008, 22:16
  5. Creaking from front - 03 1.8 SXI
    By addyboy1982 in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2007, 21:14
