Results 1 to 10 of 17
Thread: spanner light ... NO loss of power /performance??
    Regular Member Marty J CDTI's Avatar
    Feb 2006
    Yeovil
    Default spanner light ... NO loss of power /performance??
    Had this twice today on starting the car no loss of performance etc, and on switching off the ignition it cleared it? Any thoughts or should I take it into the stealer? How much does it cost for them to check out the car? I knew I should have changed it before the warranty ran out!!
    Its a 1.9cdti
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    glow plugs getting low voltage.. if so then easy to change yourself.. my 1st guess anyways...
    Feb 2006
    Yeovil
    ok so is that battery on its way out or the plugs themselves?
    Feb 2006
    Yeovil
    The handbook says it could be water in the diesel filter? Anymore recommendations before I go and gingerly see the dealers
    Nov 2007
    Quote Originally Posted by Marty J CDTI View Post
    plugs themselves... i had the same problem few weeks ago bought 4 new plugs for £9 each. fitted them and hey presto all better...
    Feb 2006
    Yeovil
    are they decent quality plugs?
    Feb 2006
    Yeovil
    Is there a how to on this or is it self explanatory? Should really get myself a haynes now!!!
    Regular Member EURO G's Avatar
    n ireland
    dont know if theres a how to but there fairly easy to do just make sure you get the engine well heated up before you try to take them out they have a tendency to wring off then its major problems,ngk r go quality plugs about £9 or so youll need a pair of needle nose pliers,a 10mm deep socket and ratchet,disconnect the electrical plugs unbolt the plug ,put the new plug in recconect the electrical plug and so on for the rest hth
    Feb 2006
    Yeovil
    excellent mate ta, I'll go on the hunt for these then. Has the haynes manual come out for this car yet? Might have to crack on and get one. Might even do a write up if i get chance.
    Newport
    Vauxhall charge around £50 to do a diagnostic on the car, thats what i got charged last week
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Spanner light & loss of power
    By kamar in forum Vectra C / Signum Troubleshooting
    Last Post: 9th January 2013, 23:10
  3. loss of power / service spanner light
    By cookie01 in forum Engine & Drivetrain
    Last Post: 9th August 2011, 11:11
  4. Spanner light on but no loss of power
    By jonesy1 in forum Engine & Drivetrain
    Last Post: 1st May 2010, 12:58
  5. Loss of power and spanner light!
    By martinhill in forum Engine & Drivetrain
    Last Post: 3rd February 2010, 18:48
vauxhall vectra c 1.9 cdti spanner light no loss of power
