Results 1 to 10 of 30
Thread: CD70 Bluetooth Phone list
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Default CD70 Bluetooth Phone list
    Does any one know if there is a list of phones that are fully compatible with the CD70 bluetooth HU?? I have a nokia N95 8gb which connects up and works fine with the cd70 except for the phone book, i have to either go thru the phones contacts or know the actual number i want to dial, i cannot access the contacts on my phone thru the cd70, even though there is a phonebook section on the cd70 screen but it doesn't seem to do anything, do i have to import them into the HU at all?? i dont mind changing my phone if i have to..
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Pete, this is a common problem with some phones and the Vauxhall bluetooth. I have had best results with Motorola, no problems at all in fact. Previous Nokia's and Sony's all gave the problems you describe.
    There is an update via tech2 available from the Dealers. It takes about 30 minutes. The update was released around March 2007 that helped to cure these problems and also added some more features to the bluetooth menu.
    Paul.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I found my Sony worked perfectly with the VX kit in a loner I had. Aren't the N95's a bit problematic anyway?
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    I've not had any problems with the n95 as yet but i will look into getting a new phone now.. Hopefully my car will have the cd70 update, but i will give the stealers a call in the morning. i just read on the nokia forum that there is a program to download to my phone that should resolve the phonebook problems, so i'll do that in the morning aswell and see if it works, if not then onto orange for an upgraded phone me thinks....
    Cheers for the info Guys..
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Well i've just tried the connectivity program that i downloaded from nokia;s website and it still doesn't work (well it work to make and recieve calls )I called the stealers and they confirmed that my car has the latest cd70 software, So im now on the look out for any suggestions or info on new phones that do work with the cd7 bluetooth and that will let me use the phones contacts... Any help as allways is greatly appreciated..
    Somewhere I probably shouldn't be
    N95 (and I think most N-series) don't fully work with many BT kits. My girlfriends Jag doesn't allow the names to work, but does with her Nokia
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    I think i've found out why a lot of new phones including my N95 don't work fully with the cd70, A lot of new phones are bluetooth V2 and the CD70 is Bluetooth V1.2 And there are a lot of known issues with different bluetooth versions not working correctly with each other, So i need to buy a new phone that is V1.2, Luckily the new Nokia E61i (similar to a blackberry) is V1.2
    so im going phone and see if i can upgrade to one on a trial basis to check it works with the car... If it does i'll take it, if not it'll go back and try something else until i get one that works..
    I found the specs for the cd70
    here:- https://www.bluetooth.org/qualweb/Pr...ProductID=2473
    Opel Universal Handsfree Phone ComBox Delphi Corporation
    Automotive handsfree unit
    Bluetooth identifier : B02237
    Assessment Date : 2005-05-20
    Spec version : 1.2
    PRD version : 1.0
    Product ID : Delphi MY05 OPEL UHP 13187911
    Software Version : 1.8.B11
    Hardware Version : IP9 Rev.G
    Qualified Product Notice : B000022S-01-P-uns.pdf
    Compliant Portion : CPD-B000022S-01-P-uns.pdf
    Qualified profile : - GAP
    - HandsFree-Unit (1.0)
    - SDAP
    - SDP
    - Serial-DevA
    - Serial-DevB
    Interop Devices : - -
    Product Type : PROD
    List Date : 2005-05-20
    Product Contact Person : Jens Arvidsson
    Email : jens.arvidsson@mecel.se
    Phone : +46 31 720 45 64
    Company URL : http://www.delphi.com
    Jun 2007
    n ireland
    my phone wont stay connected with bluetooth. it will stay on for a couple of minutes then just cut off, then just go back on etc.used to work better at the start. dont even connect to it now at all.too much bother!!!
    Jan 2006
    Norfolk
    As far as I can ascertain its the Series 6 Nokia phones that dont work properly these are the ones with the Symbian operating system all the series 4 work ok such as the 6310I 6820 etc.
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    A little update, I've now found out that i need a phone which has a bluetooth profile called "PBAP" Which stands for Phone Book Access Profile.. Most phones seem to have this except for the nokia S60 series of Symbian phones (N Series) as already mentioned by Bowler above.. Apparently Nokia don't installed PBAP on the Symbian phones such as my N95 because they make their own car kits which have access to the phone book without PBAP.. :-) Thanks nokia.. So im now looking at Sony, motorola and blackberry phones..
  1. Bluetooth Phone list
    By Big-Pete in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2017, 08:14
  2. CD70 Bluetooth/Phone Flashing "Phone Safe"
    By mgsc00840 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 08:15
  3. CD70 Bluetooth/Phone Flashing "Phone Safe"
    Last Post: 14th November 2011, 23:13
  4. CD70 and Bluetooth Phone Help !
    By valvebg in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2009, 13:50
  5. Phone list
    By Maverick in forum Irmscher Factory Road Trip - 13-16th April
    Last Post: 5th April 2007, 17:06
