Results 1 to 10 of 13
Thread: colour fade
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default colour fade
    can anyone tell me what is the best solution for bringing back my vauxhall red,as i find it hard to bring to the deep red it should be.
    Chester
    Red cars are a nightmare. If its going pink you'll need to get it polished. I've only seen this done with a machine polisher but the results were stunning. Not sure how effective it would be by hand.
    Then you'll need to protect it. I use Nattys Red Wax on the missus red Astra following some advice I was given by a professional detailer.
    There's a thread from a meeting somewhere showing the polishing. I'll see if I can find it.
    edit: This is the one. http://forum.vectra-c.com/showthread.php?t=31331
    The wax Iain is using is very expensive which is why he suggested Nattys Red.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    if it gone really pinky red then you will need g3 cutting compound and a electric polisher (like a 9"angel grinder) with a mop head on it put be carefull that you dont burn the paint
    Regular Member dave16v's Avatar
    Jun 2007
    Scotland
    Vehicle : Ampera, Astra Sri
    Trim : Sri
    Engine : 1.4 hybrid, 2.0 cdti
    so many products out there now, but i stuck with the one i liked best i did porsche,s red ,vw red, rs turbos, one ferrari red, many others as well as the other bad colour for fading white , the method i used was autoglym bufferfine or sometimes radiant but is not so good, with a twin headed pressure sensitive polisher,after taking it off i would use super resin or a carnuba wax to seal it or if i didnt have any autoglym supergloss its a sealer, i wouldnt try tcuting it yourselve as the amount of cars i had to fix on a monday after some bright spark thinking that polishing there car on a sunday was a good idea, there are many other products out there which can do the job , wee tip if you put on a polish that is being a pain to gome off put super resin over the top comes off a treat, p.s i dont rate any teflon coatings or the like, eg superguard , diamondbrite they really dont last for the legnth of time that they say and there a real pain to do
    Regular Member carlton's Avatar
    Oct 2006
    Planet Earth
    I once had a "Flame Red" Cavalier, and the tops of the mirrors turned into "Pastel Pink" in a couple of years of owning it, that was back in 95, but it seems that red cars just cant stop fading, even with the new technology in paint composition..........never again...nearly every Vauxhall on the road from that era is going, or is pink in patches, you would think they would have got it right by now, doesn't seem to be as bad on Fords!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Do modern "solid" paints have a clear coat like metallics?
    Full Member Big Sig's Avatar
    [QUOTE=carlton;509025]I once had a "Flame Red" Cavalier, and the tops of the mirrors turned into "Pastel Pink" in a couple of years of owning it, that was back in 95, but it seems that red cars just cant stop fading, even with the new technology in paint composition..........never again...nearly every Vauxhall on the road from that era is going, or is pink in patches, you would think they would have got it right by now, doesn't seem to be as bad on Fords![/QUOTE]
    Strange how all the fords I have owned all started to go a bit pink too with out regular polish....
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    the new paint system has clear coat.. so no more fading flame reds.. just had mine resprayed due to a botch job by the insurance... as some little scroat keyed it.. had a whole respray of one side and the rest of the car didnt match.. in the end.. the whole car was done with clear coat too
    Etwall Derbyshire
    hi have just joined this site i have a vectra 1.8ls and the four way heater control only works on number 4 any ideas what the problem is
    h
    cheers Dave
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by david johnson View Post
    h
    cheers Dave
    Welcome mate. Its best if you start your own new thread rather than hijack someone else's. There is also a search facility at the top right of the forum so you can see if the subject has already been covered. Have a look at the thread below for your fault and post in there any questions you have. HTH
    http://forum.vectra-c.com/showthread...ghlight=blower
  1. Brake fade??
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2009, 18:42
  2. What car colours are the most fade prone?
    By boogiemaster@blueyon in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2009, 22:43
  3. Brake fade !!!!!
    By corman in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2007, 08:13
  4. Re-Map = More Power = Brake Fade???
    By BigMan in forum Diesel Engine related
    Last Post: 18th July 2007, 18:06
  5. Interior cloth fade..
    By R-man in forum Detailing and Car Care Discussion
    Last Post: 27th September 2006, 14:34
