Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Another 1.9 cdti 150 with no power, low rpm
    Scotland
    Angry Another 1.9 cdti 150 with no power, low rpm
    Yep my sri 150 cdti is suffering from low rpm lack of power.No lights come up on dash , car runs fine , just no power below 2k rpm . Was fine till last week.Checked swirl valve operation and that seems fine . Had it in at the dealers today ,wtf , they told my wife there is nowt wrong because no codes come up on the diagnostics . Car has done 14k on a 56 plate. Dealer said that as nothing showing then they cant fix it . aparently they dont get paid to investigate a fault under a warranty , just fix what shows up when on the machine . Will be phoning vx tomorrow , see what they say. Could the egr valve be playing up? Can it be checked ? Can it be cleaned? Am i just imagining the whole thing ? arghhhhhhhh.
    Regular Member yorkiebar's Avatar
    Jun 2006
    N.IRELAND
    Quote Originally Posted by bigboss View Post
    is this not just the way the car is as mine is not that sharp below 1800 rev`s as well but after that goes fine.I think this has been said alot on this forum but am sure someone will let you know mate
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Mine has very limited acceleration below about 2200 & then takes off like a train, especially with the BSR remap. Had Vx look at it a number of times & been told 'there's nothing wrong with it' & 'they're all like that' - Basically, no warning lights means no fault
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    TBH i think its a trait of Vauxhalls and i blame rotten clutch. I feel if you don't give it juice, the engine hits a 'flat spot' til about 2,000rpom then it goes like stink.
    I think it's the cr4ppy clutch.
    Gazza4
    grimsby
    mine doesnt have that much power under 2000rpm specialy if in the wrong gear but when it hits 2000 puls like a train must be the norm but then only had my 2006 plate for 2 weeks
    Scotland
    Point taken guys , but car seems more flat than normal ! had it for nearly a year now
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    try the airbox mod.. I found it made a difference on my previous SRi
    Mar 2007
    Southport
    Try the BSR mod.. I found it made a BIG difference.....
    grimsby
    is the airbox mod the one where you remove the intake pipe
    and does it make big difference if so will do when my k&n filter comes
    then bsr ppc remap
    Scotland
    Eh , this seems to be turning into a tuning advice thread ,ha ha . Tbh its quick enough for me as it is . Does the airbox mod make it spin up a bit faster ?
  1. No power from 1.9 cdti 150
    By garetmcc79 in forum Engine & Drivetrain
    Last Post: 1st April 2012, 08:04
  2. 1.9 cdti 150 no power
    By baz_cdti_sri_150 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 15:00
  3. little power 150 cdti
    By smokydiesel in forum Engine & Drivetrain
    Last Post: 26th May 2010, 19:13
  4. 150 cdti with no power
    By pauly in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 00:23
  5. 150 Cdti down on power??
    By shrekster in forum Engine & Drivetrain
    Last Post: 7th December 2008, 00:19
vauxhall vectra loss of power when accelerating
vauxhall vectra 1.9 cdti loss of power
vectra c 1.9 cdti lack of power
vectra 1.9 cdti low power
vectra c 1.9 cdtivectra c no powervectra c 1.9 cdti no boost1.9cdti weak boost at low rpmvauxhall vectra 1.9 cdti losing powervectra diesel no powervauxhall vectra no power when acceleratingvauxhall vectra 1.9 cdti diesel lost powervauxhall vectra 1.9 cdti clutch is lowvectra 1.9cdti 150 lack of powervectra cdti low boostvectra c no rev 2009Loss of power vauxhall vectra1.9 cdti low rpm powervectra down on power at low rpmVectra cdti 150 not acceleratingloss of power for signum 1.9cdti 07vectra c 1.9 turbo loss1.9 cdti low powervauxhall vectra 1.9 cdti 8 valve no accelerationz19dth feels down on power
