Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Passenger Seat Airbag removal
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default Passenger Seat Airbag removal
    Anyone done this? How hard is it?
    Sunny Dartmoor
    Wouldn't like to try it,but i read on here, as long as you disconnect the battery for 5 mins then remove airbag it should be safe enough Roy,its all about discharging the unit,not sure how they unbolt though,sure someone would know.........
    as above.. disconnect the battery and leave the car for 15 mins minimum..
    the side airbag is secured at it's bottom edge with one fixing..accessed when the seat is out of the car..
    @home
    Engine : 1.9 CDTi
    I've took them out before (just not on this tpye of car), like you say they must be discharged, just wanted to know how to get thing thing out as there is a plastic cover on it and I don't want to break anything.
    @home
    Engine : 1.9 CDTi
    Cheers Mark. Can this not be done while the seat is still bolted in and pushed forward?
    best withe the seat out.. unless you fancy standing on your head....
    @home
    Engine : 1.9 CDTi
    just being lazy.. I guess three bolts won't take long.
    @home
    Engine : 1.9 CDTi
    Mark, have you taken any out? need to replace the cover as it's scratched, are these part of the airbag or separate?
    Sunny Dartmoor
    Mark you know everything...........
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Hi mate,
    just been out to remove my one. Plastic cover is part of the airbag. Remove the bottom piece as it just prizes of. Then you have to take the seat out again
    Then the airbag itself is held in by two nuts at the back. It was the passenger one?
    Take the plug out underneath the seat and leave for 5 mins tho.
  1. passenger seat airbag
    By fa\tfingers in forum Bodywork & Interior
    Last Post: 16th August 2011, 21:01
  2. Airbag replacement - NSF (front passenger airbag)
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 19th February 2011, 21:12
  3. Passenger Airbag
    By heaths in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 06:41
  4. Drivers seat Airbag Removal
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 15:10
  5. Front seat airbag removal
    By monkeybusiness in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 09:27
vectra c seat airbag removal
vauxhall vectra passenger airbag removal
how to change airbag in Vauxhall Vectra C drivers seat
vectra c seat airbag removal site:www.vectra-c.com
replace airbag vauxhall vectra seat
replacing vectra c seat airbag
removing passenger airbag vauxhall vectra
vectra c seat aitbag
vectra c front seat airbag removal
