Thread: any previous alfa owners maybe help me with a problem?
    Regular Member EURO G's Avatar
    n ireland
    Default any previous alfa owners maybe help me with a problem?
    as above my friend has a alfa 156 and his bottom drivers door hinge has worked its way loose anyone had this problem or can help?
    Jan 2008
    NW - Cheshire
    Sorry mate can't help, I had almost every other problem with my alfa just not seen this before!
    Jan 2008
    NW - Cheshire
    get your mate to log onto alfaowner.com seems to be a few articles on there, sorry about the early post forgot about my membership!
    <<QUOTE>>
    My bottom door hinge went on the front drivers side. The chassis side of the hinge where the pin goes in broke. New hinge £12. Didnt need door side luckily as thats welded into the door!
    Just be careful lining and adjusting it otherwise you'll get leaks which is what I had. Took a bit of fiddling but is ok now.
    Easy enough to do, just disconnect the wiring plug by pulling up the clip and yanking it off, undo the vertical bolts that go down through the pin, lift off door then undo chassis bolts (get some new ones!) replace with new hinge then put it all back together.
    Took me about half an hour plus days trying to get it lined up and adjusted (easy enough to do). You may have to readjust the striker plate too.
    Its a common breakage according to the local alfa stealers bodyshop. <<ENDQUOTE>>
    The alfa owner forum is a pretty good place, similar to here al the guys are pretty friendly. A good source for info for you pal.
    Regular Member Padster72's Avatar
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    Quote Originally Posted by stepheng View Post
    My Alfa 156 was a dream, even had the Selespeed gearbox, but not even a hint of any problems. Think I must have been really lucky. Sorry I can't help.
  1. Subaru Impreza WRX previous owners.
    By SillyMoose in forum The 'Off Topic' room
    Last Post: 18th September 2011, 08:26
  2. Any Previous Jag XJ6 N P R Reg owners out there?
    By hertscol in forum The 'Off Topic' room
    Last Post: 18th May 2010, 20:45
  3. Previous owners
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 12:11
  4. FAO all Previous B owners
    By Andy in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2006, 21:27
