Results 1 to 10 of 27
Thread: Computer Boffin Required
    Regular Member silverhairedracer's Avatar
    ESSEX
    Default Computer Boffin Required
    I have a problem with my PC that is running on Windows XP can anyone help ?
    1/ My plug & play Samsung MP3 player is not reconised
    2/ I now have a TOMTOM 520, and that is not being reconised either,...although it does sometime get reconised,it shows on the device manager,it does not Auto start its programme.
    I know that both the MP3 & tht TOMTOM work as I have tried them both on my daughters laptop
    I am told I need to back up my computer and re load windows...next problem the F drive [cd writer] is stating not accessable !,so I have purchased an external hard drive ......guess what? when I plug it in to the USB ports it is not reconised.
    I feel that I have a chicken & egg situation here
    Any suggestions please ?...that a numbnut can understand.
    Jan 2008
    No idea....
    Uninstall your chipset drivers, (will be intel or something like that depending on your motherboard). Restart, then download the drivers from the motherboard manufacturers website. Restart and all should be well. If its not then your motherboard may be giving up (ive had this before at my work) or you could to do a repair install of xp if its not hardware related (you wont lose any data). Hope this helps a bit..!
    Nicking Ya Dinner.
    1 - Just reboot
    2 - Control panel -> add hardware
    3 - Computer management, see if it shows up in disc config
    4 - Have them connected at boot up time.
    Or your USB cable is cacked.
    ESSEX
    Quote Originally Posted by RobDMX View Post
    If I reinstall the cHipset drivers or a repair install of XP.will I not need to do a back up of My documents /photos etc first ?
    Nicking Ya Dinner.
    Repair XP is like find the gremlin in a car fault, you'll probably end up with NTLDR missing or something similar, use the find new hardware 1st and if that doesn't work try another cable.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Quote Originally Posted by silverhairedracer View Post
    Chipset drivers NO
    XP YES
    ESSEX
    Followed your method VV,but when I hit the add new hardware it did not show up after its search,
    It has got to be somthing to do with widows as it all the "mass storage" devices that do not get reconised ie MP3,TOMTOM,& the ext hard drive,so that brings it to the chipset route,how do I find them ?,do not forget you are dealing with a silver haired computer numbnut here
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Have u done a windows update?
    http://www.update.microsoft.com/micr....aspx?ln=en-us
    Do this and install all the updates, this usually sorts most problems
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Are u using the USB ports attached to you PC?
    If you are, are they the ones at the back or front of the PC?
    ESSEX
    Tried all the USB ports front & back
  1. Computer help required desperately
    By blues n twos in forum General Chat
    Last Post: 17th March 2010, 20:46
  2. Computer Guru Help Required!
    By KSD in forum General Chat
    Last Post: 9th June 2009, 14:41
  3. Buying new computer help required
    By Gr4eme in forum The 'Off Topic' room
    Last Post: 16th November 2008, 23:40
  4. Computer help required
    By siadwel in forum General Chat
    Last Post: 6th December 2007, 11:10
  5. Computer help required
    Last Post: 23rd July 2007, 14:18
