Thread: oil leak
    nottinghamshire
    Angry oil leak
    hello, help required on my 2.2 dti vectra, after washing of leaking oil from the engine to find the leak (now leaking so much it is spilling out the undertray onto the road) i think it is coming from the brake pump and the rocker gasket? does the brake pump require filling with oil when replaced with a new gasket? as its now making a rattling noise after leakin out as i cleaned the surface off before refitting....
    now oiled up the pavement outside the house to, not good!
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    do you have pic's that might help
    Midlands Mod Shop - NFFC.
    nottinghamshire
    not at the moment, i took the brake pump off to have a butchers and it is much worse now! going to get gasket from the stealers tomorrow and fit it on wed, fingers crossed, i will be changing the rocker gasket as well as that is leaking to......
    yep.. if it's leaking get it all changed..
    The vac pump is normally never touched.. they either work or they don't..
    Have a good look at the oil pressure switch buddy as that is quite a common failure on DTi's and oil will get everywhere !!!!!!
    nottinghamshire
    Thumbs up oil leak
    thanks for the reply, got the gaskets from the stealers today so should be setting about it on wednesday, i should all being well have a workshop manual by then as i like to torque things, the vac pump has stopped it racket so it must have filled with oil,
    i will be taking a few pictures so i will post them when i get the chance..
    nottinghamshire
    Thumbs up
    Quote Originally Posted by Drinky View Post
    i have not looked at that yet but will be doing now you have mentioned it
    nottinghamshire
    Smile oil leak
    well i think i hav sorted out the leaks, rocker gasket and brake pump both done and no leaks yet!
    what a mess when i took the under tray off! i have had to take off the matting as it was full of oil and just dripping out as i took it off, i have done around 30 miles and no sine of a drip yet!
    nottinghamshire
    Smile
    Quote Originally Posted by norby View Post
    oh boy what a leak! took the whole under tray off and found that the cap on the oil pump was finger tight! got the socket on it and now sorted, not a drop more used in 1500 miles........
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
opel vectra 2.2 dti oil leak www.vectra-c.com
vectra leaking under tray
opel 2.2 dti leaking oil radiator
