Results 1 to 10 of 22
Thread: Shaking steering wheel
    Larkhall
    Default Shaking steering wheel
    My steering wheel shakes like mad when i go over 60 with these new tyres on.
    Went to see the guy who fitted them who said they were balanced fine and took quite a lot of weight to balance. It shook when i went over 75 with the old tyres but this is much worse!!
    I would guess it is the balance but any ideas?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Put the back wheels on the front to see if this makes any difference. If the problem stops then you know its the wheels. If it continues something more serious.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Check the tyre pressures, I had the exact same problem and found that the tyres were under-inflated - 26psi when they should be 32psi. The shaking stopped.
    Gazza4
    Larkhall
    The guy who fitted them said they were at the correct pressure. If i swap them with the back and the shaking stops would it affect the handling of the car in any way?
    Admin plasma's Avatar
    On the Forum
    267 Post(s)
    Engine : 150
    Mileage : 74000
    Does the steering wheel feel likes its having a pendulum feel or just normal wheel vibration?
    The guy may have put too many weights on the tyre. Over weighting theses can be as bad as no weights at all. If you swap ends with the wheels and they are that badly out of balance you'll feel it roughly underneath the floor pan near the drivers seat as it transmits the vibrations through the car. As for handling i dont think it would have any adverse effect
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    your wheels are out of balance or you might have a new tyre out of shape
    Larkhall
    I went and spoke to him and he said to come back with the car tomorrow after work.
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    Mine was like this with the old Nankang tyres I had on.... the harsh ride and vibrations from the tread caused a wheel balance weight to be thrown off and that caused quite an alarming shakeing sensation at the steering wheel.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by T4M View Post
    Check yourself just to be sure. I always assumed that when tyres are fitted they would be inflated to the correct pressure but I found out they don't seem to do that
    It will be something simple anyway.
    Gazza4
    Larkhall
    I'm kind of doubting buying these cheap tyres now!!!!!
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. steering wheel shaking when braking
    By n8sby in forum Suspension, Wheels & Brakes
    Last Post: 12th May 2011, 16:22
  3. shaking steering wheel
    By chrisknights in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 23:32
  4. Steering wheel shaking around 70-80mph
    By stampede in forum Suspension, Wheels & Brakes
    Last Post: 5th April 2010, 16:27
  5. Shaking steering wheel
    By peppered in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2009, 08:19
vectra c steering wheel shakes
vectra c shaking when braking
vectra c shaking when braking www.vectra-c.com
