Results 1 to 10 of 16
Thread: HID's Installed - Now got Engine Management Light on
    Darlington
    Default HID's Installed - Now got Engine Management Light on
    Just completed the install. Lights work fine. No light warning on the console but I now have the engine management light on.
    I disconnected the mass air flow sensor plug when doing the passenegr side, other than that the only electrics were the bulbs.
    I've just disconnected the battery as I read this may cure the problem.
    Thoughts please
    Admin plasma's Avatar
    On the Forum
    259 Post(s)
    Engine : 150
    Mileage : 74000
    The airflow sensor plugged back in ok? Did u try to start the engine with the MAF unplugged?
    If fault is no longer present the spanner light will go out after 25restarts or so
    Darlington
    You've hit the nail on the head. Started car to see how bright the lights would be. Only when I came to putting it all back together did I plug in the MAF sensor.
    Management light was still on after battery was reconnected after 30 mins. Leaving it for a few hours.
    Car drives okay. Will it go off in time or is it a trip to Vauxhall?
    Will this impact performance in any way having the light on and the computer thinking something is amiss?
    How much to Tech2 if this is required?
    Regular Member rmt's Avatar
    Cambridgeshire
    As said, after 25 or so restarts the light should go out !
    grimsby
    where did you get your hids from do they look good now its dark and where they easy to fit
    cheers
    Darlington
    HID's from Ebay
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=310015627447
    The quality wis excellent and they look really good in the dark. I also fitted new side lights from MTEC. Here's an install of the kit
    http://www.nicoclub.com/articles.php?id=212200
    There are a few posts in here that show typical before and after shots on a Vectra. Install was pretty painless and you definately don't need to remove bumper or lights
    grimsby
    did you have to cut any wires or was it just plug and play
    how long to they take to come fom hong kong
    cheers
    Darlington
    No wires to cut. Purely plug and play. Hardest part was finding a hole cutter to cut a 24mm hole in the plastic back to the light. The cutting took seconds to do. There is a post on the How to for a HID install. The HK kit doesn't require to cut the cable and join a pink connector.
    Delivery was 4 days.....and no Import tax as seller describes item with little value and "light sample".
    I was apprehensive about doing the job after I read a few threads, especially taking the bumper off, but as it is possible with just removing the air box and water bottle filler, job took 90-120mins all in. Pretty straight forward.
    On the Forum
    259 Post(s)
    Engine : 150
    Mileage : 74000
    Your spanner light wont effect performance at all, the warning was to let you know there 'was' a problem but not no more because it goes off after starting the car. Hope you enjoy your HIDs
    Quote Originally Posted by plasma View Post
    I got the impression from reading this thread that the spanner light was still on after the car was started.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
engine management light is on after fitting hids
fitted hids now management light is on mu zafira
