Thread: Changing rear siggy springs, is this the bolt to undo
    Regular Member eaglepva's Avatar
    Up North
    Default Changing rear siggy springs, is this the bolt to undo
    Hi, Im changing the springs on the siggy tomorow and had the wheel of for a quick look today while washing the car. Can anybody tell me if this is the bolt i undo and is that the arm i put the trolley jack under to slowly let the arm down to release the spring? and where is the best place to put the axle stand.
    Thanks for your help.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    the one at the very bottok then yes that is the bolt
    yep.. support the car under the steel subframe by the shock absorber....
    then undo and remove the long cross bolt before letting the jack down gently...
    Here, there and every where!
    I jacked the car up under the jack point and undid the bolt. No need for a trolley jack m8. There is no pressure on it and you will have to push down hard on the arm to get the rubber seating of the spring to free it The new spring is shorter so again should not need jacking up to refit the bolt. I jacked the arm up for support more than to compress the spring.
    Don't take my word for it though, Mark has done far more of these so i'd follow his advice
    you flatterer..:..
    i use the jack as an assist only.. but it's necessary in 'world record' attampts.... helps bring the arm up gradually to help it realign with the void bush and to get the holes in line..don't be afraid to drive the bolt through to realign it before tightening it up again
    Up North
    you flatterer..:..
    What do you mean drive the bolt throught, Whack it with a hammer
    yep.you can garuantee that the bolt hole in the void bush won't be straight.. so tap the bolt through and the bush will align
    Regular Member VECTRA_C_VIPSTYLE's Avatar
    CHESTER
    Default lower it
    Did mine last wk put spax 40mm drop all round did the whole car in 2 hours
    Jack the back up on the bottom leg use an axel stand in the middle of the car. Use a trolly jack under the lower bar pump it up so it just takes the strain undo the lower arm bolt use a punch to push it out then lower the jack the arm should drop down.Remove the jack a use a pry bar to push the bar down towards the floor.Pull the top end of the spring off first the rubber will prob come off with it.Pull the spring towards the rear of the car and it shoul come free.
    re fit: put a small amount of copper ease on both rubbers and replace them,With the pry bar push down and put the bottom of the spring on first,Then the top,
    Put your trolly jack under the arm and appy copper ease to the outer edge of the arm this will help with recetin the arm, Jack the arm up slowly
    till the hole's match put your bolt threw tighten and walla done should take about 20 min (check mine out ) laffin, Used spax 40mm drop
  1. design springs on a siggy elegance??
    By Dti Neil in forum Handling & Braking
    Last Post: 14th February 2012, 23:54
  2. Sourcing Front Coil Springs for Siggy 2.0 T
    By tone in forum Suspension, Wheels & Brakes
    Last Post: 15th May 2009, 10:18
  3. Anybody up north want to fit 2 front springs to siggy
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 09:16
  4. changing springs
    By kenny1zero in forum Handling & Braking
    Last Post: 30th June 2008, 02:12
  5. Cost of changing rear springs
    By gekornro in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2008, 20:04
vectra c axle stand points
