Thread: Just a quick 1 regarding washer jets
    Regular Member LAV6Y's Avatar
    Oct 2006
    Lisburn, NI
    Default Just a quick 1 regarding washer jets
    I'm now onto my third veccy and i notice a differece in this one when i use the screen wash. I need to hold the stalk for a second or two before any water appears. When i pull the stalk i can hear the pump going but, as i said, no water appears for a second or two.
    I have searched and found a few threads relating to ''gunged up'' pump filters.
    My question is: Do you think this is as simple as the pump filter being blocked or does it sound like the pump is on its way out.
    PS: When the water does come it sprays totally fine....Maybe i'm just being too fussy.
    Thanks for your help guys.
    sounds like the strainer/filter on the end of the pump is gungy.. check the little valve after the pump as well as this prevents drainback...just unscrew the front screws of the nearside wheelarch liner to gain acess..
    Oct 2006
    Lisburn, NI
    Thanks Mark,
    Once i screw the wheel arch liner off is the pump obvious to a novice?
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    Yes, the pump will be attached to the washer bottle and have a couple of hoses leading away from it
  1. washer jets
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2011, 07:40
  2. Washer Jets
    By VikBee in forum Troubleshooting
    Last Post: 23rd December 2009, 09:06
  3. washer jets
    By steve-wolves in forum Bodywork & Interior
    Last Post: 21st December 2009, 18:13
  4. Are there any better washer jets out there..
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 20:45
