Thread: screen washer pump
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    Default screen washer pump
    have noticed the last few days poor washer jets thought it was the cold but the same today...
    pump making a right din..
    any one know how much a new washer pump is .. and can it be done without taking the bumper off like it says in the new haynes book..not been underneath to look yet
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    As mentioned on this thread
    http://forum.vectra-c.com/showthread.php?t=41673
    Turn the front wheels to the right. Remove the two front screws in the f/n/s inner wing to release the plastic inner wing. Pull the plastic out and you will see the washer bottle and the pump. Pump just pulls out. You can then pull off the two water pipes. The electrical connector has a clip. Bit of thought and it is easy to remove.
    I would imagine that the filter at the bottom of the pump is gunged up. Mine smelled like a sewer. But if you need a pump you have it in your hand.
    When you put it back make sure that its pushed back firmly so that it won't leak. Fill with water to check before putting everything back....
    yep.. work via the wheelarch...
    new pump (unlikely it's needed) is about £15..
    As john said.. more likely the strainer...
    Oct 2007
    Leicester
    Trim : Elite vxline
    Mileage : 80000
    cheers guys will take a look weds morning when i finish work.... is there only 1 pump that does both front and back as can ony see 1 when ive looked under the car
    Jun 2007
    in a white box
    I believe just the one as there is only one filler bottle. So would make sense to have only one pump.
  1. No power at the Washer pump
    By DTI Dave in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2015, 15:49
  2. Screen washer help pls
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2011, 15:24
  3. Screen washer problem - Please help
    By MattW74 in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2010, 12:04
  4. Washer Pump
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2008, 13:29
  5. washer pump
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2008, 15:37
