Thread: Sport button
    Regular Member Bullylad's Avatar
    Bolton
    Question Sport button
    HI,
    My first post on this forum so here goes.
    I have just been reading an old What Car mag and in it they compare the Vectra against the new Mondeo, Passat and Toyota.
    They show an internal picture of a Vectra 1.9 cdti (148 bhp) SRI XP.
    If it is correct it shows that this model has the 'sport' button fitted. Does the diesel Vectra have this as an option?
    MY '06' 148 SRI does not seem to have it fitted. Is it only installed on on the XP model?
    I have read the posts about the traction control button that can be fitted and sometimes work or don't depending on which wiring loom you have in your car.
    Is it the same principal with the sport button or is there a bit more to it?
    Hope this makes sense?
    Regards, Bullylad.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Hi Bullylad, Welcome to the site..
    The sports button comes with the optional extra IDS+, i think its an option on all vectras, once pressed in it alters the suspension settings, power steering and throttle response...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Apparently the only model that has it as standard is the VXR. No prizes for that one LOL.
    Gazza4
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If it's the same as Astra's, the throttle response change isn't very intelligent. All it does is change the position of the pedal where WOT is, ie full throttle comes sooner on the pedal's travel.
    Not exactly sure how it can change the suspension setup, unless there is some sort of hardware alterations, but I have only driven Astra's with this function and didn't look under the wheel arches for any actuators - but I didn't really notice any difference in suspension with the button ON TBH.
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    as found on google for the non believers amongst us "the IDS+ set-up incorporates Continuous Damping Control via sensors on the top of each shock mount.. the system uses ecu's to manage the car's suspension and braking, maximising grip"
    and also this
    "Select ‘IDS+ as an option and Vauxhall fits electronic dampers that are a genuine advance for this sector. With these, the body control is flawless and roll is cut further as they stiffen automatically in corners. If you want the ultimate ‘sports’ feel, press a button on the dash and the steering weights up, the throttle sharpens and the dampers adopt a suitably firm setting."
    And it defo works...
    Regular Member Ean Vectra Vxr's Avatar
    Jun 2007
    Peterheadshire
    Sure does work even on the vxr
    Regular Member Voxer's Avatar
    Ayrshire, Scotland
    Quote Originally Posted by Big-Pete View Post
    and also this
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    and also this
    I hope the 'electronic dampers' last longer than standard Vx dampers
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Yeah me too Ian, they sound expensive...
    Regular Member VectraV6CDTi's Avatar
    Wilts
    So if they can fit the sport button to the Astra SRi as standard, why cant they do it on the Vec SRi as standard? Is it because the Vectra must have the IDS2? The Astra doesnt have IDS2 (I dont belive) so why cant it be fitted like the Astra? Vx being tight again .
  1. sport button
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2012, 21:47
  2. sport button, traction control button
    By Denbro in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 23:44
  3. sport button
    By afcbadam in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 22:20
  4. Sport Button
    By Maverick in forum Parts for sale
    Last Post: 3rd March 2010, 22:44
  5. ESP and sport button
    By mspvxr in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2008, 19:53
