Thread: Vectra rear bake pads
    Derby
    Default Vectra rear brake pads
    Can anyone offer me some advise on my 2.2 sri rear brakes? Just changed the front pads which was really easy, but when it came to the back I couldnt budge the rear pistons to fit the new pads in. Any ideas would be welocme.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Quote Originally Posted by steveo83 View Post
    I'm to slow
    Derby
    Smile Vectra rear brake pads
    As a new member, not sure if Im using this thread thingy right. Many thanks to Stevo83 for your photos.
    It was the winding in of the pistion where I was going wrong! Tried in vain to push it back in like the front one's, but was obviously doing it wrong!
    Well, thats tomorrows work planned!
    Thanks again
    just hope you haven't damaged the thread.. wind them back in very carefully..
    Derby
    Eek Vectra rear brake pads
    If its knackered the threads ive only got myself to blame. Should have joined you guys before going ahead! Sure it will be OK
    if it doesn't wind back in even with the correct tool, then it's new caliper time....
    Derby
    Mole grip method didnt work. Called out local mechanic with correct wind down tool and the job was done in half an hour. Phew! thought I had stripped the thread, but this tool applied pressure as well as winding in the piston.
    Always use the correct tool for the job.
    yep..lesson well learnt..
  1. Rear brake pads for a 2006 Vectra C SRI
    By trendwarfare in forum Handling & Braking
    Last Post: 6th February 2010, 15:04
  2. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
  3. Rear Brake Pads on Vectra CD
    By elfanno in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2007, 08:57
  4. rear disc pads Vectra C
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2006, 21:48
