Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Air Box Mod Done....
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    Default Air Box Mod Done....
    Just done this now, cleaned all the dead leaves and cr@p out of the box.
    Going to take it for a blast up the motorway to see if it makes a difference. Hope it does!
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    will deffo do mate..............enjoy...........
    Midlands Mod Shop - NFFC.
    cambs
    hi
    it doesn't make a big differance but it will seem smoother and remove the flat spots when pulling away and getting upto speed
    May 2007
    hoovered all the dead shyte out of the box and also cleaned the filter element. Power delivery is far smoother now and it picks up much better without the need to drop down a gear.
    Just need to raid the coin jar for the K&N filter now.
    EVERYWHERE
    Don't forget to reset the ECU (disconnect the battery for 30 mins) when you fit the K&N filter.
    May 2007
    Quote Originally Posted by diesel dog View Post
    any particular reason??
    EVERYWHERE
    Quote Originally Posted by andrew the bobby View Post
    When you alter anything with regards to air intake increases or fuel increases (tuning boxes),it is always a good idea to allow the ECU to 'learn' about the new amounts of air or fuel that are being fed in.Disconnecting the battery wipes the memory clean.
    You don't need to do this after a remap because the ECU already knows.LOL
    May 2007
    ok - gotcha. Will I have to find my radio codes to unlock it or will that be ok?
    it'll be okay for about 15 mins without the battery
    May 2007
    cheers for that - the little bit of plastic removed really makes a difference IMO.
    far smoother now.... and seems more economical!
